Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 03-13-2011, 11:08 AM
tomovsb is on a distinguished road
Question about Linistepper v2
Hi everyone!
For a long time i try to create the CNC router, for my hobby (r / c models), I made ​​different drivers, but I have not yet managed to put together something that works.
I spent a lot of time reading the posts on this forum and on pminmo, collecting your experiences. I decided that my new drivers to be linistepper. The easiest, cheapest and safest way would be to buy them, but I have quite a good supply of electronic components, so I would still want to do alone, and I enjoy to make things.
I study linistepper for long time and can conclude that I am able to make linistepper driver, but i still need help.
The only thing that interests me, for now, is: Is it enough to create a hex file with MPLAB from ASM file attached to linistepper page, or earlier should be adjusted somewhat in the asm file.
To be clear, I will use the PIC16F628A, if i create a hex file directly from Lini_asm_v21 file, whether it's ok or i need to adjust something in asm file before creating hex file ?
a lot of respect ,
Tomislav
Old 03-13-2011, 11:20 PM
James Newton's Avatar
James Newton is on a distinguished road
That should be fine. Just set the correct device, PIC16F628A, in MPLAB.
Old 03-14-2011, 03:17 AM
James, thanks for your response, your answer has confirmed my desire to make linistepper.
And big thank to Roman, for sharing his knowledge and information.
Sincerely,
Tomislav
Old 03-19-2011, 12:55 PM
Here is my progress with linistepper.
I used brd from Sam Waters and squize it a little and add few vias.
I also replace crystal with ceramic resonator like on the original schematics.
Board is now 4,5cm x 6,2cm.
Few resistors and switch is missing but i will add them soon. I don't have them now.
Any coment are welcome !
Old 03-19-2011, 02:18 PM
Drools's Avatar
Drools is on a distinguished road
nice looking board. Is it DIY or do you have access to some professional equipment.
Old 03-19-2011, 04:10 PM
tomovsb, that looks good! Toner Transfer? One thing I'm a bit concerned about is the power resistors... is there actually room for them? Be sure to leave lots of space for them to cool. E.g. don't solder them in right next to the board and separate them from each other. I may just not be gauging the available space correctly, but they look really close together and small. Also, if you want to drive more than 1 amp, you need to be able to add a second set or find power resistors with less than 1 ohm. Keep us posted?
Old 03-19-2011, 04:27 PM
Thanks, it is toner transfer, top layer is toner transfer too.
I will put power resistor in vertical position and between each other will be about 5-6 mm.
I don't plan to drive motor bigger than 1A, but i will add a place for tuning resistor.
I will post my progress with linistepper here.
Old 03-19-2011, 04:34 PM
Here is pcb
Old 03-20-2011, 01:17 PM
Ah... I didn't think of standing them up... makes sense.
Old 03-22-2011, 03:15 AM
James, you was right, i've never worked with such a large resistors so now, when i got it, i see that i have a little problem with them, in the reality it is much larger than the eagle drow on the pcb, there is no room for them, even if i put them in vertical position, but i may come up with something.
I will post picture when i finish.
In the meantime, I have deal with the interface board.
This is my DIY PMinMO 4 axis, ( for linistepper ) .
  #11   Ban this user!
Old 03-22-2011, 12:49 PM
You can probably mount those power resistors off the board... I don't think a little extra lead length will make a difference... there will be some power running through those leads so watch out for any data cables running near the wires.... just like you would with motor leads. Shouldn't be much of a problem. Perhaps you can figure out some way to mechanically mount the resistors since the leads will be too long to reliably support them.
You know, GeckoDrive puts the current sense resistors on the motor side of a connector so that the setting "goes" with the motor if you switch motors out. I don't suppose another header would happen to fit in place of those power resistor pads? Then you could call it a feature instead of a bug! LOL...
  #12   Ban this user!
Old 03-26-2011, 03:27 PM
Yes, but I decided to make a new pcb, and resets the elements.
Now I added pins for tuning resistors.
Thanks for the advice !
I still didn't get those missing components yet, but i will soon.
Linistepper in C hazimin PIC Programing / Design 9 01-23-2011 08:34 PM
Need Help!- Linistepper troubleshooting shadesdude Open Source Controller Boards 6 06-29-2009 08:42 AM
Linistepper update posix Open Source Controller Boards 56 10-14-2008 01:20 PM
'Lil Linistepper Lathe epineh Mini Lathe 37 02-24-2008 08:03 AM
Linistepper tante Open Source Controller Boards 7 12-19-2005 09:24 AM
