Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 07-14-2005, 07:22 PM
Seventeen is on a distinguished road
BEST Open source Controller ?
Please tell me what is the best controller for cnc with 3 axis ?
Thanks for your help
Old 07-15-2005, 01:19 PM
James Newton's Avatar
James Newton is on a distinguished road
Mine of course!
http://www.piclist.com/techref/io/st...step/index.htm
Seriously, you haven't given anywhere near enough information to answer that questions accuratly.
The Linistepper is probably best for older unipolar motors (cheap, pull from old printers, fax, copiers) at 1.5 amps/phase (up to 3 with some tuning) and for driving loads that need to be turned very smoothly so that complex and expensive drive reduction systems can be avoided. Examples would be telescope or other optical mounts or small cnc systems where you need better accuracy more than you need power and speed. The Linistepper controller will run hot, but the motors will run cooler than they would with a chopper type controller.
The Linistepper is NOT for: Bipolar motors. It is not a power house and not intended for huge currents or massive loads. It is pretty quick, but not a speed deamon. It gets HOT and needs a HUGE heat sink.
There are many other controllers out there and I'm sure others will list what they are and (I hope) will try to describe what is best AND worst about each design.
Old 07-15-2005, 04:34 PM
pminmo's Avatar
pminmo is on a distinguished road
Seventeen,
What are the specs of the motors you are driving?
Phil
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 07-15-2005, 04:51 PM
zoltan is on a distinguished road
Hi Phil,
Have you had the opportunity to check the diodes?
Thank you,
Zoltan
Old 07-16-2005, 02:47 PM
pminmo for the moment i don't have motor !
My CNC is very big (200 cm x 150 cm)
All in Aluminium, i seach the best motor and best controller for my applicatin !
I send a picture twomorrow !
Picstep v4.0 (http://www.fromorbit.com/projects/picstep/) is good ?
(with this interface http://pminmo.com/3axisopto/3axisopto.htm)
THX and hello from France !
Merci encore !
Old 07-16-2005, 03:33 PM
pminmo's Avatar
The picstep is an excellant board for a bipolar motor. If your router is big, you better select a motor first. Then select the electronics to drive it.
Phil
Old 07-17-2005, 06:34 AM
OK thanks for your reply,
I find one motor, but i don't know if it's good or bad motor for my application.
Motor reference 57BYG060/04 bipolar 2A,2.6v /phase
Or have you a reference to be proposed to me ?
Old 07-17-2005, 10:30 AM
pminmo's Avatar
For that motor rating, either the picstep or the 3977.
Phil
Old 07-17-2005, 11:11 AM
pminmo Thanks, but this motor is good ? (power, speed, .... ?)
If yes, I take 3x this motor and picstep v4.0 + interface 3axisopto
Bien le Bonjour de France mes amis !
Old 07-17-2005, 01:34 PM
pminmo's Avatar
I was not able to find any info on the motor, so I couldn't really say. Yes, you would need three motor driver boards. You have options on how to connect them to a pc. Either of the 2 interface boards, or you can discretely wire. i.e. one DB25F connector and a few feet of 22 ga wire.
Phil
  #11   Ban this user!
Old 09-02-2005, 03:27 PM
masaV is on a distinguished road
what is better/good driver board to 4Ampere or highes bibolar stepper motors?
(can made bcp itself)and where i found dc servo board schematic? want test servo driver too(I have one old servo motor vhat run DC 30V very slow.dont know more detail thats motor)
encoder have this.
but need biggest motor my cnc and big current board.my board max current(all l298boaRD)2,4A what is very small.my cnc tread is trapetsoid and 4mm/r.and need cut to metal what torgue need in motor?
linear X-Y is 800mm and Z is 110mm.
(Z trhead is 2mm/r)
  #12   Ban this user!
Old 09-02-2005, 06:21 PM
pminmo's Avatar
At this time there is no OS board that will do 4A bipolar or higher. That is one of my goals this winter. Just today I received a 4A nema 34 motor to be a test bed. I just have one almost ready that will do 3.5A continious 4A peak. Full step or half step, chopped current limiting. I took a little different design path with. It has both the 10 pin IDC connector for interoperability with the other OS boards, but also has a 5pin screw terminal that can be intalled for discrete wiring. Also put opto isolation on the step, direction and enable lines, and they have signal conditioning in front so they should be ok with laptops. Just need to come up with some bucks to get a prototype pcb. It is a double sided pcb, not what I would consider toner transfer capable. Pic attached.
Open source Eagle pcb files TinkerDJ Open Source Controller Boards 13 05-02-2006 03:28 AM
Open Source CNC Controller Specification gregmary DIY-CNC Router Table Machines 28 12-04-2005 10:58 PM
What's in work at the open source pminmo Open Source Controller Boards 0 02-13-2005 02:55 PM
Web space available for open source cnc ShayArnett Open Source Controller Boards 1 01-11-2005 10:31 AM
Open Source Gecko 201 Look A Like? pminmo Open Source Controller Boards 5 11-06-2004 11:51 PM
