Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 07-05-2005, 09:22 PM
pminmo's Avatar
pminmo is on a distinguished road
Question Debating 3977 3 axis
I've had this design done for a couple of months. It's a 3 axis all in one design based on the Allegro A3977SED. (connector for connection to a 4th axis via one of the Open soucre boards) To be perfectly honest, right now I just don't have the time, energy and spare cash to order, build and checkout. A LOT of the design is cut and paste from previous designs, so it should be pretty low risk. If there is a person(or persons) out there that is interested in persuing building one for themselves, willing to help pay for the proto board's, contact me offline. Needs to be somebody that is not a novice to electronics, and doesn't need a lot of mentoring. You should be able to get a board and the parts for around $75 without the A3977SED's.
Phil
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 07-28-2005, 03:47 PM
zoltan is on a distinguished road
Hi Phil,
Right now I started to build joe's version of 3977. I have built the boards. Actually, I found out another local supplier of presensitive boards which are working great with my homemade UV box. Unbelievable what quality in just 2 min. I made three boards of 3977 and three of picstep and they are without any defect. Not even a deviation of width of trace under a microscope!!! So, to make the long story short. Send me the files (Eagle) and I will build it. I bought six broken printers (mechanics failure) with 3977 SED inside.
Zoltan
Old 07-28-2005, 07:24 PM
pminmo's Avatar
It's a double sided board. Much finer pitch than the others.
Phil
Old 09-21-2005, 08:08 PM
philba is on a distinguished road
how are you guys soldering the PLCC 3977?
My first attempt at hand soldering was a complete disaster - several bridges that no wick would get (i've got the really thin stuff for smd). I've got a hot air station so I may try that or maybe the sparkfun hotplate method. Any suggestions?
I haven't got any solder paste (yet...). Would just tinning the pads and fluxing the leads do ok? Should I tin the leads as well? I'm going to make some test boards for a sacrificial PLCC test, hopefully today (after I fix my shop lighting that the *!1&^%!! electrician left in a mess. grrrrr).
Old 09-21-2005, 09:22 PM
*Registered*
HobbyCNC is on a distinguished road
Phil
Got a parts list to go with it?
Dave
Old 09-21-2005, 11:18 PM
pminmo's Avatar
philba,
Fine soldering iron and a flux pin. I use a .032 round tip.
Hobbycnc,
I haven't ordered a pcb yet. I've actually tweeked the design some by making it opto isolated.
Old 09-22-2005, 12:02 AM
*Registered*
philba,
Hobbycnc,
Hmm...You ask for help in prototyping it and I wanted to see the BOM. How can someone help without a BOM?
Dave
Old 09-22-2005, 04:48 PM
pminmo's Avatar
If there is a person(or persons) out there that is interested in persuing building one for themselves, willing to help pay for the proto board's, contact me offline. Phil
Dave,
I'm not sure what part of the message you didn't undertand.
Old 09-22-2005, 06:11 PM
*Registered*
Dave,
You ask for help in building one and I'm asking what the BOM contains to understand what's involved in helping you build one.
Dave
Old 09-22-2005, 08:06 PM
pminmo's Avatar
QtyValueDeviceParts
1F25HPX8
2G04RRN2, RN3
1LED3MMLED1
3Header-1X2JP2, JP5, JP10
2Header-2X5JP7, JP9
3R-TRIMM64WR29, R35, R38
17.1uf2.5mm ls 35vdcC6, C8, C21, C22, C25, C26, C27, C28, C29, C34, C35, C36, C37, C38, C45, C46, C47
6.22512smd 2WR11, R12, R15, R16, R19, R20
1.22uf2.5mm ls 35vdcC20
9.22uf1206 smd 35vdcC2, C4, C5, C9, C10, C11, C12, C15, C16
101K1/8WR2, R4, R24, R33, R36, R44, R47, R48, R52, R53
52.2K1/8WR23, R32, R34, R45, R46
22N22222N2222Q1, Q2
64.7K1/8WR13, R17, R21, R22, R26, R30
110K1/8WR3
610K1/8WR5, R6, R7, R8, R9, R10
110uf tant2.5mm ls 16VDCC7
651K1/8WR14, R18, R25, R27, R28, R31
274HC14D74HC14DIC2, IC3
6100uf2.5mm ls 35vdcC1, C3, C13, C14, C17, C18
23901/8WR1, R54
1470pf2.5mm ls 35vdcC19
96801/8WR37, R39, R40, R41, R42, R43, R49, R50, R51
61000pf2.5mmls 35vdcC23, C24, C30, C31, C32, C33
178057805 to220IC1
3A3977SEDA3977SEDU$1, U$2, U$3
1ISO5VW237-02PX9
1NKE0505SNKE0505SDC1
1TLP624TLP624OK4
4TLP624-2TLP624-2OK1, OK2, OK3, OK5
1VDCW237-02PX1
1XO1W237-02PX3
1XO2W237-02PX2
1XRateHeader-2X2JP1
1YO1W237-02PX6
1YO2W237-02PX4
1YRateHeader-2X2JP3
1ZO1W237-02PX7
1ZO2W237-02PX5
1ZrateHeader-2X2JP4
Header reference .1 spacing male IDC header
W237-02P reference 2 pin screw terminal
  #11   Ban this user!
Old 10-06-2005, 05:07 PM
Originally Posted by zoltan
Hi Phil,
Zoltan
what printers have the 3977 in them?
  #12   Ban this user!
Old 10-06-2005, 05:41 PM
They have been some industrial printers - Oliveti. They have been used on assembly lines.I bought in total 10 pcs, all of them not working, as I was told they had some mechanical problems (the guy who brought them to the recycling company told me), but only six had A39977 inside and the other four, same type, had controllers with A6615SED (I did not check what IC is it). I did not record what was the name of printers, but for sure they have been Oliveti because I did not pull out all the components from boards and I still have them. As here you do not find very easy new parts and when you find out they are very expensive, I am buying broken or old printers, scanners, faxes, cashier counters, etc from a recycling company. Because they sell everything by kilograms I am going there and disassembly on spot the equipments and pull out the boards, motors, etc, and pay only for kg of material I want.
Be aware that you can not desolder A3977 without a hot air gun.
Zoltan
Hypothetical 1 axis 3977 board pminmo Open Source Controller Boards 12 04-14-2005 04:41 PM
My new little baby 3977 pminmo Open Source Controller Boards 6 03-28-2005 02:45 AM
2 axis to 3 axis conversion drembedded Bridgeport and Hardinge Mills 10 10-27-2004 12:32 PM
Proto 3977 COntroller pminmo DIY-CNC Router Table Machines 6 04-02-2004 09:18 PM
