Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 10-27-2010, 12:18 PM
rlwoodjr is on a distinguished road
P and N type Mosfet Servo Driver
First let me say I am a newbie to electronics. I wanted to build my own motor driver for a cnc router. I started a thread using a FAN73832 high/low side driver, but could never get it to work for very long. Thank you SgtWookie (from All About Circuits Forum) for all your help. I have abandon the project and move to an different one.
This circuit has both P type and N type mosfet's. In the given circuit, the logic that turns on the high side, also turns off the low side. Since the P mosfet's take 15 us to turn on and the N mosfet's turn off in less than 1 us, there is no shoot-thru. I designed this circuit on a simulator named SIMetrix-SIMPLIS. Simulation was real close to the real board.
I have gone to IRF5210's and IRF3710's for my mosfets. The micro-controller is the ATMEGA328P programmed with the Arduino software.
I am by no means done with this and would welcome any suggestions for a more robust design. I have tested this board for about 5 weeks and have not been able to break it. I still need to work on the firmware to the ATMEGA.
Old 10-27-2010, 12:31 PM
I am running 56 VDC, 2 to 3 amps motor turning at around 4000 rpm.
Test I have run so far:
1. A three second full speed (280 IPM) each way, no pause or deceleration in firmware (ran for a couple of hours)
2. long g-code file with Turbocnc connected as step/direction input
3. One second down to one millisecond back and forth at high speed. ( motor heats up, but the driver mosfets are a steady 122 F.
Here is my test setup. 16 TPI stationary screw with 1:1 belt drive. I plan to use 20 TPI for the router.
Old 10-28-2010, 10:55 PM
chinsettawong is on a distinguished road
Nice work!
Newbie- Best MOSFET Driver and MOSFET choice for an H-Bridge Stepper Driver? joprinz General Electronics Discussion 4 04-28-2011 03:57 AM
Need Help!- FAN73832 for Mosfet Servo Driver rlwoodjr Open Source Controller Boards 10 10-27-2010 12:15 PM
Mosfet Driver tivoidethuong General Electronics Discussion 57 01-18-2009 09:20 PM
Experiance with the HIP4082 mosfet driver? AbSat General Electronics Discussion 0 07-01-2007 06:17 PM
IR2184, HIP4080A, or other for mosfet driver? originator Stepper Motors and Drives 2 11-02-2006 09:31 PM
