Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 04-08-2010, 11:22 PM
khite is on a distinguished road
Question A3977 Questions?
So on pminmo.com it stats the the stepper driver A3977 can only handle upto 2.5A. When I read the manual it talks about using a fan if current is higher than 2.5 and pmdx.com,http://www.pmdx.com/PMDX-150, has a board that can handle up to 3A. My question is,
1. can I use the design from pminmo.com, http://pminmo.com/forsale/1X72805c.pdf, and use it at 3A with the proper cooling?
2. What is the difference between the pminmo.com and pmdx.com design?
3. If I use the pminmo.com design what size power supply. I am designing one from the DCS1 at pminmo but need to know what voltage to determine the resistor values
Old 04-09-2010, 09:24 AM
spainguy is on a distinguished road
The A3977 data sheet states :
ABSOLUTE MAXIMUM RATINGS
at TA = +25°C
Load Supply Voltage, VBB ............. 35 V
Output Current, IOUT .................. ±2.5 A*
So do not attempt it, fan cools the IC, and use a PLCC heatsink like http://uk.farnell.com/fischer-elektr...c-w/dp/1222501
Old 04-09-2010, 04:47 PM
Jesse B's Avatar
Jesse B is on a distinguished road
The A3977 uses a ground plane on the bottom of a chip for cooling, so heatsinks only help so much. The best way to cool these chips is with a large ground plane, which leads to a larger PCB. I wouldn't not attempt running more than 2.5A, which is higher that would be recommended regularly. 2A would probably be the highest you'd want to pull through these for any extended period of time.
If you need more amperage, there are plenty more affordable options out there.
A few A3977 boards available now Xerxes Open Source Controller Boards 4 11-07-2010 03:38 PM
Newbie- Quick Questions about A3977 Jesse B Open Source Controller Boards 4 12-10-2009 10:13 PM
A3977 fyhyj Open Source Controller Boards 7 12-27-2007 02:52 AM
A3977 Woes jcdillin Open Source Controller Boards 1 09-22-2006 10:30 AM
a3977 driver TigerPilot Open Source Controller Boards 1 03-26-2005 08:18 PM
