Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 03-11-2010, 09:11 PM
KC Chin is on a distinguished road
Question PMinMo L297-8, Out1 & Out2 and stepper motor polarity
Hi all,
Manage to have the 3 x L297-8 drivers and "DIY 4 Axis PC interface" works without much problem except I burned one 7805 and one stepper motor(Vref too high). I am glad that all 3 axis worked with the 6 wire bipolar motor with my try and error method.
I am curious about certain thing.
1. Which output is for A+ A- B+ B-?
Out1= X3-1, X3-2
Out2= X2-1, X2-1
2. As for stepper motor, I have 6 wires stepper (unipolar and bipolar).
I managed to determine those 6 wires
example
1, 2, 3 group A, A2=common
4, 5, 6 group B, B5=common
How to determine the polarity A1 & A3 and B4 & B6 which wire is + and -?
TIA and cheers
KC
Old 03-12-2010, 12:47 PM
James Newton's Avatar
James Newton is on a distinguished road
http://techref.massmind.org/techref/...pper/wires.htm will help you find which wires are which on the motor.
http://techref.massmind.org/techref/...onnections.htm the table below the graph will give you the options for how to connect the stepper to the driver. In your case, with the 6 wire motor and a bi-polar driver: The common A and common B are held apart and not connected to anything. A+,A-,B+,B- to bipolar driver with 41% higher voltage than the motor rating.
As to the polarity, I don't have a lot of experience with Bi-polar motors, but I believe it's the same as for unipolar motors: Just hook up the controller A+, A-, B+, and B- terminals to the phase leads (guess at the phases) and try to step slowly.
If the motor does not turn, try swapping one A wire with one B wire, you may have connected the motor phasing wrong. If you have the phasing wrong, the motor will tend to sit there and "wobble" or "buzz".
If the motor turns, but in the wrong direction, you only need to swap the two A wires with each other.
Old 03-12-2010, 08:09 PM
Hi James,
That the method I had been doing for getting the bipolar stepper to turn correctly.
As for the L297-8, I am trying to find out, wasn't documented, Out1 and Out2 polarity.
Well, have a good day.
PMinMo L297-8 bipolar driver resistance watt KC Chin Open Source Controller Boards 4 02-02-2010 05:45 AM
l298 l297 driver 2A with stepper 3A help chawkiz OpenSource Software 4 06-05-2009 10:09 AM
PMINMO A3977 or L297-8 Driver? cnc-newb Open Source Controller Boards 10 01-19-2009 07:43 AM
L298/L297 strange stepper motor noises cnc kiwi Stepper Motors and Drives 7 12-26-2007 11:18 AM
kcam4 and pminmo l297-unipolar contr. amakarevski Kellyware CAM 4 10-31-2007 11:28 AM
