Hi. I have got some stk6713 stepper drives and have been using them with success.
Here is a post of mine with the pic of the drive.
http://www.cnczone.com/forums/showpo...2&postcount=10
As I understand, the STK6712 does no uses a "current sensing" the 2 resistor that you must choose simply LIMIT the current. It is a voltage divider circuit.
Here is a configuration I have used on my drives, I am not sure if 6712 and 6713 are pin to pin compatible, but might be, so beware.
Since the STK67(12/13) are 4 phases input I have used l297 to enable the drives to use STEP/DIR signals.
Next time you test something, try using a fuse to save your electronics.
Code:
Mach 3 Dir and Step active LOW.
/*********** L297 wiring *************/
PIN CONN NAME
1 NC SYNC
2 GND GND
3 NC HOME
4 PIN_9 ON STK PCB (I wire this through an inverter 74ls04)
5 NC INH1
6 PIN_11 ON STK PCB (I wire this through an inverter 74ls04)
7 PIN_10 ON STK PCB (I wire this through an inverter 74ls04)
8 NC INH2
9 PIN_12 ON STK PCB (I wire this through an inverter 74ls04)
10 +5V ENABLE ***NC for now***
11 GND CONTROL (10kOhm resistor to GND pulldown)
12 +5V Vs
13 GND SENS2
14 GND SENS1
15 GND Vref
16 NC OSC
17 DIR CW/CCW
18 STEP CLOCK
19 +5 HALF/FULL (HIGH IS HALF) (10kOhm resistor to +5v pullup)
20 NC RESET
NOTES:
GND signal must be connected to GND on the BOB board to equalize ground planes.
/************ PCB STK 6713BMK4 PCB *************/
J143 CONNECTOR
1 GND
2 GND
3 GND
4 Vcc1 +18 - +42V
5 Vcc1 +18 - +42V
6 Vcc1 +18 - +42V
7 GND
8 Vcc2 +5 IOH SETTING CIRCUIT
9 PIN 13 on STK6713 A PHASE
10 PIN 15 on STK6713 A' PHASE
11 PIN 14 on STK6713 B PHASE
12 PIN 16 on STK6713 B' PHASE
13 Vcc2 +5
STK6713BMK4 IC Pinouts
PIN --- NAME
1 Vcc2
2 A phase motor output
3 'A phase motor output
4 PG motor ground
5 SG motor ground
6 B phase motor output
7 'B phase motor output
8 TD1 (motor hold noise reduction use cap with pin 10)
9 Vref
10 TD2 (motor hold noise reduction use cap with pin 8)
11 Vref
12 NC
13 A phase input
14 B phase input
15 'A phase input
16 'B phase input
Standard motor connector J144
PIN --- NAME ---------- MOTOR LEAD COLOR
1 COMMON BLACK
2 COMMON WHITE
3 MOTOR A COIL RED
4 MOTOR 'A COIL YELLOW
5 MOTOR B COIL BLUE
6 MOTOR 'B COIL ORANGE
CURRENT LIMITING RESISTORS
Formula is Amps = 1.3*(R2/(R1+R2))*(5.2/0.33) (5.2 is my Vref voltage [pin 8 on J143 connector], use your logic [+5 or watever] voltage in the formula for more exact results
Amps --- R1 -- R2 value in Ohms
0.91A - 4700 - 220
0.94A - 3300 - 160
1.07A - 1800 - 100
1.09A - 3900 - 220
1.34A - 4700 - 330
1.46A - 4300 - 330
1.59A - 3900 - 330
1.70A - 3300 - 300
1.86A - 3000 - 300
1.86A - 3900 - 390
2.01A - 3300 - 360
2.03A - 3000 - 330
2.14A - 4700 - 550
2.16A - 3300 - 390
2.18A - 3600 - 430
2.19A - 3000 - 360
2.27A - 2400 - 300
2.32A - 4300 - 550
2.35A - 3000 - 390
2.36A - 3300 - 430
2.36A - 3600 - 470
2.47A - 2400 - 330
2.54A - 3600 - 510
2.55A - 3300 - 470
2.67A - 1800 - 270
2.67A - 2200 - 330
2.67A - 2400 - 360
2.74A - 3300 - 510
2.75A - 3600 - 560
2.82A - 1000 - 160
2.86A - 2400 - 390
2.88A - 2200 - 360
2.92A - 1800 - 300
2.97A - 3300 - 560
