Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
Old 02-12-2010, 05:57 AM
jazz352060 is on a distinguished road
Need Help To Get My Router Up & Running
Hi all,
For several years now, I have had the desire to build my own CNC Router. However, after many hours of reading Posts on this Forum, several attempts at building the basis of a machine, I finally gave up, although I still had to have a CNC Router.
Now, I have done it the easier way. Having recently retired, I decided to purchase a home built CNC Router that suddenly became available.
After driving to Adelaide to collect it in my Ute, I have managed to put it back together. Correctly, I hope.
I have pictures but as yet have not loaded them into the computer, so for now, a brief description will have to suffice.
Electronics:
Stepper Motors x & y axis 430oz-in, z axis is smaller, also have spare 430oz-in, ie.4 motors total.
3 x M542 Microstepping Drivers
2 x 40vdc Stepper power supply
1 x 12vdc power supply
for interface between motors and computer is the C11 break out board from CNC4PC
Emergency stop button, Microcontroller based Safety Charge Pump
Table:
Steel Frame construction, with structural aluminium gantry
Y axis Linear rails - vxb bearing blocks on 20mm x 1600mm solid ground hardened steel.
X axis linear rails and leadscrew is salvaged from an old IBM pick and place machine. lead nut has some slack in it.
Z axis constructed from solid aluminium plate, has nsk? i think ballscrew, with nsk? linear bearings 16mm dia.
Brand new miluwakee speed adjustable die grinder 7,000 - 30,000rpm
Shop Vac for the dust 1300watt, 5m long hose
I also have a variety of endmill/slotdrill/ ball nose cutters.
However, I am reluctant to switch it on until I am more confidant that I have hooked all the wiring up correctly. Some of the Posts that I have read have mentioned 'Blue smoke' and that seeing it is not good.
Given my level of expertise in electronics, I have probably wired the ON switch to the blue smoke release circuit.
I really don't want to see that blue smoke.
I live in St. Albans, and would appreciate it if someone who knows a lot more than I do, could spare the time to visit and and check my machine to make sure it is safe to switch on.
Just send me a PM and we can go from there.
Did I mention that I am very keen to have my machine running.
Regards,
Albert
P.S. Knowing that pictures are very important to everyone, I will get onto them and post them tomorrow.
Old 02-17-2010, 05:05 PM
Gold Member
RomanLini is on a distinguished road
Any photos??
Running times on router Horseman Gorilla CNC Machines 9 12-24-2009 09:40 AM
Need Help!- Getting my Router up and running fuelsguy CNC Wood Router Project Log 19 05-29-2009 10:59 AM
Mini router up and running chuck99z28 DIY-CNC Router Table Machines 2 10-25-2008 09:19 PM
Running Mach3 with a Step four router B-Sure Machine Problems, Solutions , Wireless DNC, serial port 4 10-07-2008 11:09 PM
