Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
Old 02-09-2010, 09:02 PM
Mark Raymond is on a distinguished road
Vee bearings for linear slides
Is there some reason that is not obvious to me why more people dont use vee bearings on their linear slide.
Old 02-09-2010, 09:24 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
there are a good number of builds including mine that use v bearings , they work quite well and are fairly cheap in cost
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 02-09-2010, 11:32 PM
eigstein is on a distinguished road
the problem is not the bearings . its finding a suitable track to run them on. it seems there is no cold rolled steel angle to match up, there is a metric cold rolled that would probably do it, but it is very pricey. to grind your own may not be a good option for many. the quality of the hot rolled can be all over the place.
sincerely,
rjs
Old 02-09-2010, 11:49 PM
dertsap's Avatar
Gold Member
i used angle iron on the y and square tubing for the x axis , both worked great for me
Old 02-10-2010, 12:00 AM
judleroy's Avatar
judleroy is on a distinguished road
Since they make matching tracks for vee bearings I would think if you can't find a suitable angle to match that would be sufficient. I have always wondered why so many people avoid using these rails when using vee bearings. Is there some kind of failing in these rails or do they just cost to much for the diy community?
Judleroy
Old 02-10-2010, 12:42 AM
dertsap's Avatar
Gold Member
the proper tracks are good but expensive
this is how i set mine up next router
Old 02-10-2010, 12:54 AM
judleroy's Avatar
Derstap, that looks very sturdy. I will keep an eye out to see how it wears over time. Assuming good wear propertys it seem a good design.
Judleroy
Old 02-10-2010, 01:20 AM
dertsap's Avatar
Gold Member
from what I've pushed it to do and what I've seen of it so far i have no worry's of wear , and if or when it does pose enough wear to be an issue then the 5 bucks it will cost to replace a section won't be a problem , and probably by then I'll be sick of looking at it it and be building a new one for fun
Old 02-10-2010, 01:24 AM
judleroy's Avatar
That the zone spirit that makes this site so cool!
Old 02-10-2010, 06:48 AM
CarveOne is on a distinguished road
Cheers! Lets build a new one! Who needs an excuse anyway?
CarveOne
"A $1,000 electronic device will almost always protect a ten cent fuse."
Old 02-11-2010, 01:18 AM
dertsap's Avatar
Gold Member
CarveOne
the excuse isn't as much of a problem as finding the space to add another one , I have more fun building and upgrading then actually cutting , I'll do a few days of cutting then tear into it to do mods and add-ons , I've got about 20 hrs left to complete the last of the upgrades then there will be no more tweaks until i brainstorm how I'm going to go about adding a fifth axis
toys , gotta love em !
  #12   Ban this user!
Old 02-11-2010, 04:52 AM
denz is on a distinguished road
Hi guys,
Could some one point me to a thread that shows the bearing carriers in more detail. This looks interesting but i need more visual understanding before my brain kicks in and starts to understand
Cheers
NSK LS20 S 2x linear slides with 4 bearings "18.25 long heilcnc EBAY ADS 1 09-28-2009 07:54 AM
NSK LS20 S 2x linear slides with 4 bearings "18.25 long heilcnc EBAY ADS 0 09-18-2009 03:45 PM
NSK LS20 S 2x linear slides with 4 bearings "18.25 long heilcnc EBAY ADS 0 09-14-2009 07:38 PM
Just IN- Linear Slides from PBC Linear Assembled in Underwater Drill Pacific Bearing Product Announcements & Manufacturer News 0 06-24-2009 03:54 PM
Linear Slides v/s rail slides bryanrabb DIY-CNC Router Table Machines 4 03-27-2006 09:45 PM
