Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
  #13   Ban this user!
Old 02-09-2010, 11:56 AM
Jkountz is on a distinguished road
Nice looking build Lee, I know what you mean about Ryobi tools too. Some are good and some are really bad. I have a 12v cordless drill that I know has to be at least 10 years old and its still going with the original batteries!! I have other drills that I use more often but that little 12v still get put to good use around here. Got any more samples of the work you machine has produced??
  #14   Ban this user!
Old 02-09-2010, 12:04 PM
Sketchup file
Here is my Sketchup file for my prototype. If anyone wants to play around with it and see what you come up with feel free, Im always open to ideas!!
  #15   Ban this user!
Old 02-09-2010, 01:19 PM
nguyenst's Avatar
nguyenst is on a distinguished road
building similar machine
I am a member of Mechmate also and got the same idea as you. I wanted to design a machine similar to the Mechmate but I don't want that massive of a machine in my garage.
I settle on a hybrid similar to yours using off the shelve parts. My rails will be angle iron or just flat iron for the X-axis. I will be using parts from Ahren ( CNCRouterparts.com) for my X and Y axis. I will be starting a build log soon. I've got the X-axis almost completed with the rack and pinion drives ready to be mounted and tested.
Steven
  #16   Ban this user!
Old 02-09-2010, 02:49 PM
Sounds good Steven, would love to see your progress. Be sure to let us know when you get your build log going!!
  #17   Ban this user!
Old 02-09-2010, 06:16 PM
nguyenst's Avatar
My machine is only gonna be about 30" wide and 50" long. I am only using it to cut on 24" x 36". I like the Mechmate gantry design since it is supported better with the Z-axis in the middle. Only problem I have right now is deciding how big to make the gantry. The larger I make it, the less travel I will have on my X-axis. I do need it to be able to hold a decent size router.
Have you figure out the final sizing for your gantry/Y-car and how your Z-axis will mount to it? It's hard designing when you are trying to stick with 8020 extrusions and off the shelf parts.
  #18   Ban this user!
Old 02-09-2010, 06:50 PM
If you take a look at the pictures hopefully you can see how the Z will work. There are two pieces of angle material that hold the v bearings. The z will slide up and down in those bearings. The rack and pinion setup on the back will drive the z unit and hold it in place. ( I hope)
Most all of it will just screw together with machine screws in tapped holes. Im still working on the weight calculations of the y and z car. When I have that I can finalize my design and decide on 80/20 or just 2x4 aluminum rectangle for the main gantry tubes.
Lots of things to do still....
  #19   Ban this user!
Old 02-10-2010, 06:45 AM
LeeWay's Avatar
LeeWay is on a distinguished road
Thanks a bunch. I have made quite a few different things on that router. Mostly production stuff, however I am nearly ready to start playing around some with all three machines I built. Router, mill and lathe.
Here are a few of the products I cut on this router. I originally cut these aluminum tailhooks on this router. Now done on the mill.
http://leestyron.com/thook/thook4.jpg
I cut these lexan parts for this overarm cover.
http://leestyron.com/cover/psi/whale_shark_03.jpg
And this cover as well.
http://leestyron.com/cover/excal/excalolder1.jpg
Then I make multiple sizes and models of these Shark Guards.
http://leestyron.com/crman/crman2.jpg
Here are some throat plates cut on this router.
http://leestyron.com/zctps/ryobi/proto.jpg
I am wanting to start doing some small signage and 3D work as well.
I already have Cut3d from Vectric and have been saving for Vcarve.
Lee
  #20   Ban this user!
Old 02-10-2010, 10:19 AM
nguyenst's Avatar
I started my build log... I hope you guys follow along and give me feedback as I go.
http://www.cnczone.com/forums/showthread.php?t=99181
  #21   Ban this user!
Old 02-19-2010, 10:30 AM
mlabruyere's Avatar
mlabruyere is on a distinguished road
Question about the mechanics of the Gantry.
Name:	Gantry question.jpg‎
  #22   Ban this user!
Old 02-25-2010, 08:33 PM
The rack and pinion, just like the real Mechmate. Also see post #8. It talks about this very thing.
MechMate 4'x8' Comprehensive Bill of Materials dmoore Open Source CNC Machine Designs 15 06-12-2011 01:37 PM
EZ-Router to MechMate Comparison dmoore DIY-CNC Router Table Machines 27 05-29-2011 03:37 PM
New Machine Build- Second Aussie MechMate built Matty Zee DIY-CNC Router Table Machines 15 02-05-2011 03:14 AM
Concept for Five Axis Mechmate with 1000mm Z Slide jksiew DIY-CNC Router Table Machines 3 03-26-2008 11:29 PM
