Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
View Poll Results: Heavy or light?
Heavy 12 92.31%
Light 1 7.69%
Doesn't matter 0 0%
Voters: 13. You may not vote on this poll
Old 01-22-2010, 08:16 PM
DEDan is on a distinguished road
Heavy or Light? 8020
I am just getting ready to start a 8020 2x3 router and I wanted to get everyone's opinion on which 8020 I should get.
I have found a great deal on the 8020 15x30 light.
Is it worth it to save a few dollars or should I go with the standard heavy type?
Thanks!
Dan
Old 01-23-2010, 01:51 AM
mlabruyere's Avatar
mlabruyere is on a distinguished road
I used heavy with my build and it's worked great. I've heard that using light will result in very bad acoustic resonance in the machine.
I wanted to use the most rigid material I could get and aford so I didn't want to compromise it by going "light".
Old 01-23-2010, 12:22 PM
Thanks for the feedback. I never thought about the acoustic issues, I was only worried about the rigidity. I guess that I will spend the extra $18 and go with the heavy 1530.
Old 01-23-2010, 01:42 PM
mlabruyere's Avatar
A 1530 beam compaired to a 1530-lite beam is about 33% more rigid
Old 01-24-2010, 06:04 PM
ilya is on a distinguished road
Yeah, you don't want the lite series - they are quite a bit less rigid than normal ones. The rigidity is something you don't want to compromise in your CNC machine.
My CNC plans at www.8020CNC.com
Old 03-07-2010, 03:09 AM
Larry83301 is on a distinguished road
Go with the best, the few bucks you would save are not worth the problems that will come from cutting corners.
I bought a machine with undersize screws, and had nothing but problems until I bit the bullet and got screws that are much bigger and better. Mine is a 36 X 48, and the new ball screws move it around GREAT. It cost a little more, but many of my problems went away.
Old 03-07-2010, 04:09 AM
lunchtrayrider is on a distinguished road
i did a similar sized build and used standard 8020 for the 3' pieces and the lite for the legs (only 6" long on mine) and for the cross pieces under the table. worked out quite well.
Old 03-07-2010, 03:39 PM
Larken is on a distinguished road
Ilya, What cad program did you do the lettering for that Preamp in ? Very nice.
Are you using both single line and true type fonts ?
Is that a Kress router ?
Manufacturer of CNC routers and Viper Servo Drives
www.LarkenCNC.com and www.Viperservo.com
Old 03-07-2010, 07:04 PM
FandZ's Avatar
FandZ is on a distinguished road
I've just built a table top for a cnc mill using 1x3 of the lite. I guess that would be 1030 and am completely satisfied with it. I also have some 2x2 of the light and am completely satisfied with it. Obviously the non lite will be more rigid, however, the light shouldn't be looked at as being an inferior product. If you're looking at whether the light or regular will cause racking or flex, I'd look at the design of the machine first. Either of them will work fantastically in a well designed machine. Neither will make a bad design better. I've seen 80/20 builds that have had some racking and flex problems using the thicker version.
I just looked at the top and realized that this thread is over a month old. So what did you end up with?
Old 03-07-2010, 08:16 PM
Larken,
I'm doing all the design work in AutoCAD and generate toolpaths in MasterCAM. Letters are done with the standard MasterCAM "engraving" toolpath.
I'm using true type fonts, no single line fonts here.
The router motor is Kress FME 1050. I really like it!
I've recently made a compressor panel with very fine engraving that looks very cool. I can post a picture if you want.
__________________________________________
My CNC machine plans at www.8020CNC.com
My DIY CNC router plans at www.8020CNC.com
  #11   Ban this user!
Old 03-07-2010, 09:25 PM
I got the heavy. I only paid $58 per 97 inch length.
Don't ask me where I got it at such a low price. It was an employee discount that my dad gets from the place he worked for 45 years. They even made him sign an agreement to not resell it.
  #12   Ban this user!
Old 03-07-2010, 10:37 PM
FandZ's Avatar
Go Daddy. Don't you just love this stuff? When I'm stressed I often find just petting some 80/20 makes me feel better. lol
Newbie- ATC Alarm Light, And Dry Run Light on after PC1 card was removed Bones75 Fanuc 3 06-18-2009 04:13 PM
Heavy is good??? zaebis Syil Products 4 05-28-2009 08:17 AM
a ring of 200 Led Lights to light up? light source render? Rich05 Solidworks 6 10-25-2008 07:16 PM
Spectra light and Light machine owners have ? ZipSnipe Benchtop Machines 11 07-18-2008 10:52 PM
Machine Recommendations Please - Light Duty, Prototyping, Light Production in metal SCG11762 General Metal Working Machines 2 08-27-2007 09:08 AM
