Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
Old 01-16-2010, 10:49 AM
monte55 is on a distinguished road
I love my lathe
Every time I have a need like this and can go to my lathe I'm Happy.
I have a PC 2.5 hp router on my CNC table. It has collets for 1/2" and 1/4
cutter shanks. A while back I needed to hold 1/8" bits so I made a small collet to fit inside the 1/4 " collet. I know you can buy them but it cost nothing to make and I needed it now. Ok....I came across a couple dozen
solid carbide 3 flute end mills for a few dollars. I went to use one yesterday
grabbing my 1/8" collet and the bit just fell through. Its shank is .1165".
So I made a collet for that size. I had a numbered bit thats .116" out of my set of 115. I don't see how I ever made it before I owned a lathe. Here are some pics. The larger bit is .072" at the cutter end and the other is .031".
Nick
ID:	97758   Click image for larger version
ID:	97759   Click image for larger version
Nick http://www.nixstuff.com
http://www.youtube.com/watch?v=jTu7wicVCmQ
Old 01-16-2010, 11:28 AM
ger21's Avatar
Probably a 3mm shank.
Old 01-16-2010, 02:50 PM
TOTALLYRC is on a distinguished road
Hi Nick,
Doesn't it make you feel good that you don't have to go buy something all the time, you can just make it yourself.
Mike.
Old 01-17-2010, 08:31 AM
It sure does. I save gas, money , and time. Also, some things you can't buy.
Old 01-17-2010, 11:40 AM
CarveOne is on a distinguished road
I love my lathe too, but my mills get jealous if I spend too much time with it. Just can't keep them all happy at once.
CarveOne
"A $1,000 electronic device will almost always protect a ten cent fuse."
Old 01-17-2010, 12:02 PM
Case in point. I am using my lathe to modify the shafts of some cheap treadmill motors to add encoders to use them as servo motors.
Having a mill and a lathe, Priceless.
Mike
@ Carveone. Both lathes get jealous when I work on the mill or the router, just like the women in my life, just can't make them happy.
Old 01-17-2010, 12:53 PM
Originally Posted by TOTALLYRC View Post
-snip-
"Been dere, done dat." I had a chance to get a second lathe recently but just couldn't do that and get the 6x26 mill also. Too bad too, because it's a fully stripped, fully restored, fully repainted Logan 10x24 belt drive lathe. I repaired one minor gear for it (back feed pull handle gear had some broken teeth) and we installed a new, larger chuck on a new backplate. Two other stripped gears were replaced with salvaged gears that were purchased online. I did the machining to bolt the chuck to the backplate and my buddy turned the backplate on the Logan to fit the chuck onto the backplate accurately. Run-out is less than 0.0015" now. The original chuck had wobbly jaws. Someone had run the cross feed into the chuck at the high school machine shop it had been stored at for most of its life. Alas, I think it has been sold already.
CarveOne
Old 01-17-2010, 04:17 PM
The Logan lathe I mentioned in my previous post here is a Model 200 and it is not yet sold.
CarveOne
Old 01-17-2010, 11:17 PM
CarveOne
Sounds like a great buy for the right person but the CK-12 Monarch that I just finished installing last week would kill me. Not to mention that I have no more room for equipment in the shop.
Mike
Old 01-18-2010, 06:06 AM
Mike
Same here. He is asking $600 for it, and there's nothing to do but pick it up, install it, and start using it. He is not able to crate and ship it, so local pick up in eastern NC only. Send PM to "Leibowitz" on CNC Zone if interested.
The CK-12 should be a nice machine to work with for sure. Old iron rulz!
CarveOne
For the love of GOD use metric! Heavy JGRO Router Table Design 193 11-21-2008 06:54 AM
Love my new AJAX!! drb_001 AjaxCNC Control Products 1 07-16-2007 10:43 PM
I Love Grex borrisl Shopmaster/Shoptask 0 07-20-2006 10:15 PM
Do you love boats? Do you love planes? CNCadmin Parts for Radio Control Models 16 03-19-2006 10:01 PM
Hmm.. got to love it Pole General Metalwork Discussion 7 08-27-2004 07:58 PM
