| Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here. |
Hi all.. Im in need of help..I am trying to design and build a 6.5 metre ( X Travel ) 100mm (Y Travel ) and 100mm ( Z Travel ) Drilling machine .. I am needing to drill a series of holes along the length of a Aluminium Extrusion. I need help with basically everything .. I have done some reading and am thinking of using R&P . But have know idea about motors or controls.. Can anyone help or point me in the right direction .. All advice welcome.. |
| Well, you said all advice, I'm pretty green, but I'd look here as a start. http://www.cncrouterparts.com/index.php?cPath=21 You can also search for threads that involve these parts R&P and Ahren who is this user http://www.cnczone.com/forums/members/ahren.html And the owner ?! of cncrouterparts, Ahren sorry if I'm misrepresenting you. There is an extremely detailed build log that gets converted to R&P using these parts. Here CarveOne's Work Table CNC Router Build no where near the length of what you want to build but might be a good place to research. Good Luck. Pete |
| Wow.....6.5M x travel. You will have to go R&P. As mentioned already Ahren has excellent quality items for use with 8020 aluminum extrusions. I would say this would be your best bet. The Y and Z can easily be done with basic lead screws and nuts. Take a look around the zone to get the juices flowing. You are going to want a gantry type machine since you probably don't want to make 6 meters of room on either side of the machine to move the material/table back and forth. |
| If the holes are in a row and not all over the place it may be easier to use a drill press with a fixture with stops that flip up in position to bank the part for each hole. I'm not saying not to make such a big CNC machine but something like this would be a lot simpler and cheaper. You sure need a lot of room to run a machine like this. Bret |
| Z axis travel | dgapilot | Shopmaster/Shoptask | 10 | 08-16-2009 08:55 PM |
| What's the most X and Y travel anyone has gotten out of an X3? | slashmaster | Benchtop Machines | 0 | 05-20-2009 03:02 AM |
| Need Help!- over travel in x at reference | Don H | Hardinge Lathes | 3 | 10-18-2008 11:12 AM |
| over travel? WTF | allmotormatt | Haas Lathes | 3 | 10-06-2008 07:03 AM |
| New Machine Build- 400-600mm z-travel?? | perolalars | DIY-CNC Router Table Machines | 0 | 03-10-2008 04:01 PM |
