Results 1 to 3 of 3
Thread: Dont know how to wire up paraller port with chip
    May 2009
    Slovenia
    Hey! I am trying to make same PC controlled stepper motor via com port.
    I have different chip (SMA7029M) and i dont know how to wire up pins from com port to controller and so on.
    Here i datasheet of my chip: http://www.allegromicro.com/en/Produ...7024/97024.pdf
    Can you help me?
    Best regards, Nejc
    Registered amishx64's Avatar
    Jul 2008
    Single Direction Chip
    That chip won't work for a CNC machine with a parallel port in the standard sense. The SMA7029M chip does not have any change direction pins, rather just MOSFET-type outputs for driving the motor in one direction. This chip basically acts like an intelligent H-bridge.
    For instance, a more standard chip for CNC machines such as the TA8435H, has a pin [5] labeled CW / CCW Forward / Reverse switching terminal. That is not present on your SMA7029M chip.
    What you could do is buy another chip such as the L297 that would act as an interface between your parallel port --> L297 --> SMA7029M. The L297 offers a direction change pin to make life easier and usable with standard CNC software. Downside is this adds price, a component and other little parts.
    L297 data sheet that normally goes with the L298N. The L298N is what you would be replacing with your SMA7029M chip. See bottom of page 1.
    If you really want, I could draw you up a schematic. Please decide whether or not you want to peruse this option before you have me put a few hours into a diagram.
    Hope that helps.
    Feb 2010
    scotlang
    hey
    hey, got a unipolar motor from a printer i have the sma7029m chip from the same printer. what other chips can i use apart from the L297? ii have a sn74hc4020 which i got from the same circuit, would that be of any use? let me know cheers
  1. Chip to Chip Time
    By Gene0552 in forum General Metalwork Discussion
    Last Post: 09-01-2010, 12:05 PM
  2. i dont know wat i'm doing!
    By flow101 in forum Europe Club House
    Last Post: 06-26-2010, 03:44 AM
  3. I need some help. Dont know what to do.
    By slammedxonair in forum DIY CNC Router Table Machines
    Last Post: 01-13-2009, 04:52 PM
  4. Paraller Port Driver - Breakout Port
    By billy in forum General Electronics Discussion
    Last Post: 11-20-2008, 08:27 AM
  5. Parallel Port Wire Length?
    By Sanghera in forum General Electronics Discussion
    Last Post: 10-27-2004, 12:11 AM
