Page 4 of 7 FirstFirst 1234567 LastLast
Results 37 to 48 of 75
Thread: CHINESE SPINDLE 2.2KW
  1. #37
    Jul 2006
    Cool looking control rig. I have the exact same Dell PC running mine. What are the DRO's displaying? Do you have another E-Stop in the loop? That position doesn't look like it's in a panic spot.
    I guess that goes to show that you can only "cheap out" so much ;-)
  2. #38
    Registered Vegabond's Avatar
    Dec 2008
    Norway
    Hello again.
    Yeah, it has just 3 leaders/connectors. Is it no ground? the motor is still need 3 leaders to run?? if it is a brushless...
    Robert.
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
  3. #39
    May 2010
    Norway
    That's right Robert.
    The VFD and the spindles are brushless as I told you on the phone, thus needing three wires.
    We'll figure out a secure way to ground it, one way or another.
  4. #40
    Dec 2008
    Norway
    Maby i need to unassamble the top of the spindel, and maby fix something under there, like it is on your`s...
    Robert.
  • #41
    Jul 2006
    Quote Originally Posted by Vaffel View Post
    Brushless VFD? Unless your machine is made of 100% MDF or HDPE, I'm pretty sure the spindle will be grounded. Check continuity with your ground bar.
  • #42
    Registered Grebbo's Avatar
    Mar 2007
    Talking
    Quote Originally Posted by scobob View Post
    Hi Scobob,
    I have installed another Estop on the monitor arm just near the monitor since I took that photo, makes it a bit more “convenient” however I must say that together with the limit switches and the soft switches I have never had to use it.
    The DRO’s are showing 5V, 12V and 48V even though it shows 38V, I still need to fine tune it, also the Dell is a very steady platform, never had any problems with it, knock on wood…..
    Mel
  • #43
    Mar 2007
    Quote Originally Posted by Vegabond View Post
    Robert.
    Hi Rober,
    My spindle is a 2.2Kw and also has 3 pin connector, I actually drilled and taped an Earth connection on top of my spindle and wired it back to my VFD (my spindle is isolated from the mounting bracket by rings that I cut from a plastic Coke bottle, makes grate spaces, however isolates the spindle from the earth loop on my machine) I highly recommend earthling you spindle if it doesn’t have good earth loop to your VFD
    Attached Thumbnails Attached Thumbnails CHINESE SPINDLE 2.2KW-spindle_01.jpg
  • #44
    Silver Member diyengineer's Avatar
    Feb 2010
    USA-WA STATE
    Quote Originally Posted by Grebbo View Post
    Hi Rober,
    Why would you want to isolate your spindle with plastic? To reduce noise emissions back into the machine and possibly into electronics? I will for sure drill and tap a ground on my too!!
  • #45
    Mar 2007
    Quote Originally Posted by diyengineer View Post
    Actually, it’s a bit of a fix rather than a purpose, when I first ordered my spindle from China, the seller gave me incorrect dimensions on the circumference of the spindle, I made the bracket and discovered that when the spindle arrived it was actually about 1mm smaller then what he claimed, so as a quick fix, I cut up a Coke bottle and hey presto! But yes, by pure chance it also isolates the spindle from the rest of the machine, thus my earth connection.
  • #46
    Oct 2005
    We have 50pcs 2.2KW and 50pcs 1.5KW spindle in our Chicago office. It is on sale now
    pls check here
    http://www.kelinginc.net/CNCSpindleandController.html
  • #47
    PKM
    PKM is offline
    Sep 2010
    Ukraine
    Another option is to use thin metal sheet - no need for earth wire
  • #48
    May 2010
    Some of the nice collets are ground to very tight tolerances, usually less than .0002".
    http://www.glacern.com/er_collets
    HOWEVER i see the ebay ones claim to be ground to .01mm
    .01 millimeters = 0.000393700787 in
    That is a pretty good deal, if you buy them test the run out with a dial indicator. I might have to buy those as well.
    Why use a collet with .0002" runout in a Chinese spindle with .002" to .005" TIR? It has been my experience that the Chinese spindles do not meet their published specs.
  • Page 4 of 7 FirstFirst 1234567 LastLast
    1. Cheap 1500W Chinese spindle, experiences?
      By matth in forum DIY CNC Router Table Machines
      Last Post: 10-17-2012, 05:06 PM
    2. Chinese CNC router
      By eadya in forum CNC Wood Router Project Log
      Last Post: 12-21-2011, 03:37 AM
    3. Newbie- should we buy this chinese laser ??
      By albo in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 06-27-2011, 02:21 AM
    4. Where to buy a Chinese 80W Laser
      By PaioX in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 09-17-2010, 03:57 AM
    5. chinese
      By wp2576 in forum OneCNC
      Last Post: 05-23-2005, 03:17 PM
