Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
Old 01-07-2009, 11:29 AM
voltsandbolts's Avatar
voltsandbolts is on a distinguished road
Question Design question. Why is it so? XYZ
Design question:
Axis name and why?
I have noticed that on a machine like the jgro for example, the Long axis is “Y” the Gantry axis is “X” and the spindles axis is “Z”
But I have seen machines where the table (long axis) is “X” and the gantry is “Y” is there a reason for this?
Or is it just personal preference?
Thanks,
RW
Deeds not words...
VoltsAndBolts Alternative Power Forums http://www.voltsandboltsonline.com/
Old 01-07-2009, 11:38 AM
samco is on a distinguished road
As long as the axis layout fall into the 'right hand rule' I don't think it matters what is the longest and what is the shortest.. imho
http://help.onecnc.net/nc/ncmain.html
http://www.rainnea.com/cnc_support.htm
sam
Old 01-07-2009, 11:43 AM
jimbo7 is on a distinguished road
The axis are based on the cartesian coordinate system for 3 axis. Drafting systems from which parts are produced are also based on this system.
Basically, if you are looking at a drawing sheet, left to right is the X axis and belly button out to infinity and beyond is the Y axis. Anything standing vertically fromthe sheet is the Z axis.
This work well for Mills. For Lathes, programmers have adopted the powered axis as Z and the axis across as X. Think of a bench mill laying down.
Old 01-07-2009, 11:49 AM
Clockwork is on a distinguished road
XYZ
The axis definition comes from the Cartesian coordinate system. Wiki does a good job of explaining it here:
http://en.wikipedia.org/wiki/Cartesi...rdinate_system
Old 01-07-2009, 12:25 PM
Al_The_Man's Avatar
The above is the way I have always seen it, and conform to.
I believe some of the differences seen on Gantry's is if the operator/control is positioned at the end of the table, some integrators will make this end the X axis from left to right, i.e. the operation of the machine conforms to the above.
Others ignore this and insist on placing the X axis on the long side, regardless of the operator view standpoint.
Old 01-07-2009, 04:52 PM
ger21's Avatar
One thing to consider is that in most CAD programs, the X is left to right, so when you design long parts, you tend to orient them along the X axis. So it makes sense for the machines long axis to be the X axis, or you'll need to rotate your parts in CAD all the time.
Old 01-08-2009, 08:09 AM
Thanks for the refresher on the Cartesian coordinate system guys.
Al and Ger I do tend to draw things in CAD with the long side from left to right, and it does make sense to set the long axis as “X” for that reason. But, do to space I tend to watch my machine cut standing at the end, so for now I have the gantry set as “X” .
Thanks for the info.
Rob
Deeds not words...
PIC Embedded design Question musicmkr PIC Programing / Design 24 07-23-2010 10:29 PM
Design question Jay325e30 CNC Plasma and Waterjet Machines 2 10-06-2008 05:27 AM
Design question AndyL DIY-CNC Router Table Machines 3 04-01-2007 03:54 PM
new table design question KTP DIY-CNC Router Table Machines 5 07-21-2006 04:21 PM
Gantry design question anthony Mechanical Calculations/Engineering Design 2 04-27-2005 01:39 PM
