Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
Old 11-06-2008, 09:24 PM
student1616 is on a distinguished road
Micro Mill
Hello all,
IN search of a simple and cute laser engraver i ended up here.http://lumenlab.com/estore/product.php?productid=16249
i like the simple portable design.only thing is i want it in aluminum with working of 12''X12''.not in nylon.and to make it cheaper i am planning to use ground brass bush over 10mm SSrod as guiding mechanism.which is supported at both the end using machines AL blocks.so can i do that? will my motion be smooth.
and for movement iam using M8 threaded rod with brass nut.
and as far as the Z is concern,i have a home made DVD laser which can do small engraving.and motors are driven by LINISTEPPER.
Assembling all of these in one piece is a issue for me,as iam not very good at mechanical.can u guys help me in understanding the alignments and drawings.
thanks and Regards
Old 11-12-2008, 12:17 PM
RiseUp is on a distinguished road
As far as their use of ground brass bushings over SS rod, many machines have been built with this pair, and glide reasonably well. Personally, I'd order a block of UHMW and bore holes to make my own bushings, but whatever you see fit.=) 10mm rod though? Awfully thin for 12" of travel, dontcha think? The thinnest I'd use is 3/8", and even that might be pushing it. I'm no expert, but what I do know is that rigidity is a must for CNC, and the last thing you want is your linear rods to bend or sway during machining.
Old 11-12-2008, 01:15 PM
Andre' B is on a distinguished road
10mm = 0.3937" > 3/8"
Old 11-12-2008, 03:43 PM
DUH! My apologies,lol. I was rather preoccupied at the moment, and wasn't thinking. 1/2" is my new answer
Coming Down to the Taig Micro Mill or Grizzly Mini Mill. SpeedsCustom Taig Mills & Lathes 15 01-22-2009 11:14 PM
micro mill millminer Benchtop Machines 33 05-03-2008 04:56 PM
Micro Mill gear fix ShayArnett Benchtop Machines 1 10-26-2005 07:09 PM
Need help with a HF micro-mill mondo50 Benchtop Machines 3 08-26-2005 09:52 AM
New to Mill and CNC - Can you mix a Mini and Micro Mill Sherpa Benchtop Machines 2 09-09-2004 09:36 AM
