| Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here. |
I have been doing a lot of searching for cnc diy and started building, I downloaded jgro plans and modified them a little, made it smaller, right now i have the wood and bearings and L angle and 1/4 -20 all thread, ..anyway guess i just got start building see where it leads and what questions arise...just wanted to say hi... |
| Well I did some drilling today, got the y rail holes drilled and the linear bearings set now i just got to cut the gantry bottom any suggestions on how to measure the length or should i just make it longer then attach it and cut it... |
well I got building a little at a time, I got the y and x axis done, I had started building after the jgro design, but modified it a little, and had the side gantry's done, but split the mdf rushing to get the bottom plate on, so i made two new pieces and routed in the L angle so far i only used 2- 2 x 4 mdf 3/4" sheets, 1-4' peice of L angle and some bolts all together about 120 dollars, I used dado's for some of my joints, working on uploading some pics... any suggestions on stepper motors and controllers kits, i will be using my dremel or roto zip for the router... does anyone have a list of links where you bought kits from... ?? |
Well I got most of the mechinical stuff done, now just got to figure out the motor size and where to buy the driver etc need a few bearings for the lead screws etc couplers etc...but its getting there found out my working space is like 15 x 18 i will post some pics soon...any suggestions on how to figure out the motor size needed? |
| I would look at these, For that size I think they would be right on. http://www.hobbycnc.com/products/stepper-motors/ Look at the 285 oz ones |
| did you ever hear of this company? http://www.probotix.com/3_axis_stepp...or_driver_kit/ how much does the size of the motor effect performance say from a 260oz to a 285oz |
#10
| Nice build there, I have started mine and will be getting the X axis done tomorrow or the next day but that looks a nice machine and I wish I had gone the angle and skate bearing approach rather than the oilite rout very unforgiving. What will you use your machine for ? |
| Newbie - To build or not to build Router/Plasma Table | dfranks | CNC Plasma and Waterjet Machines | 10 | 04-07-2011 11:16 PM |
| NEW BUILD: PVC as a build material | Smiler | DIY-CNC Router Table Machines | 12 | 11-13-2009 04:57 PM |
| New Large Table Build in Houston, TX (Build Log) | anitel | Plasma, EDM and other similar machine Project Log | 12 | 12-30-2008 02:45 AM |
