Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
Old 08-12-2008, 09:52 AM
corydoras is on a distinguished road
Out of angle machine
HI
Its been a long time since I posted here, but my machine is running pretty good now for the last 6 months, only cosmetic things left.
Since I have mostly cut out single pieces, I noticed a problem today, cutting out a fieldbox for my other hobby, rc flying.
As I was to put the pieces together I noticed that the squares are out of angle!!!!
Measuring with an angle a rectangular piece of 9mm plywood is off by 1,8 mm on a 230 mm lenght!!!, how is this possible?
My machine build can be found here, but is not updated in a while.: http://www.cnczone.com/forums/showth...t=37703&page=5
The last thing I installed a few months ago was the wire and pulleys in cross to make the gantry rock solid as it was stated in another thread here on the forum.
I have a single belt in the center of my X axis.
BTW the machine is no longer a cantilvered design.
I can post some recent photos for you guys in case you wonder on some design issues
Best reg
Cory
Old 08-12-2008, 07:03 PM
Oldmanandhistoy is on a distinguished road
Sounds to me the machine is not running square in X-Y.
Cut out a square/rectangle and measure diagonally across the corners for more accuracy and adjust the machine accordingly .
John
Old 08-13-2008, 11:15 AM
Thanx , IŽll try taht and report back
C
Old 09-30-2008, 07:07 PM
wyldesyde007 is on a distinguished road
I just came across your thread, that was my post about adding in the cable system to increase the rigidness. If you apply too much tension to one cable or the other you can pull your machine out of square (I used this feature to square up my machine as I had welded mine together and the heat deformed my rig) you can loosen one cable and tighten the other to correct the out of square situation and still keep your machine rigid.
CAM recommendation from a different angle Stepper Monkey General CAM Discussion 0 04-21-2007 04:36 PM
WTB 3-way angle vise bherr Shopmaster/Shoptask 0 05-31-2006 03:34 PM
Alum Angle Ursine DIY-CNC Router Table Machines 9 05-13-2005 06:49 AM
compound angle? fastolds GibbsCAM 3 03-17-2005 06:12 PM
Right angle spindle mccafferty CNC Machining Centers 7 07-14-2004 02:55 PM
