Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
Old 07-06-2008, 03:49 PM
Nick_Black is on a distinguished road
help me design 5axis cnc (please?)
Hopefully I'm posting this in the right place..
that's a verry verry verry rough rendering what I have flying thrue my head
the round blue disk is a rotating table to put your object on, the arms on the side are to swivel the table.
and the router is going to do the x,y,z axis (not pictured) the table is going to have a diamitor of 1m lust big enough to cut out a guitar out of a solid chunk of wood if I choose to do so. I would like it to beable to handle cutting stainless at the least. and acurate enough to make a model turbine. (0.02mm tolerence ish (0.05 might be acceptible too)
anybody have Idea's how I should go about doing this?
(yes I know a 5 axis mashiene is probably not the best thing to start with as my first project..)
Money is a concern, but I don't want it too be a factor.
and I would like it to beable to work with Mastercam X.
any help would be greatly apriciated
Old 07-06-2008, 05:05 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Nick - welcome to the CNCZone. First off - I gotta say, it is a unique approach. Given the size of working space you are considering, you might spend a lot of time. effort, and money, getting the system rigid enough to meet the desired output though.
Second, I'll add, here is a more conventional approach you might take a look at:
http://www.rainnea.com/cnc_5axis.htm
Not to dampen your design, just pointing a more typical design. I tried using the "frame as legs" as you have in your diagram -- and gave it up. It was only 3 axis and I couldn't get it stable enough.
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 07-06-2008, 05:57 PM
Thanks I wasn't too shure about using "frame as legs" iether
I've looked at using the router to move all the axis, but I wasn't shure if I could make it rigid enough., but that cnc mashiene does look fairly rigid.
whould you be able to use a normal plunge router as the drill motor? or would that be too weak?
Old 07-06-2008, 07:44 PM
High Seas's Avatar
Gold Member
Most of my metal cutting tends to be with a hacksaw - or a chopsaw
But the router works fine for wood, engraving plastics, metal plate and of course routing foam - - what-a-mess! Get a good vacuum!
Jim
Old 07-06-2008, 08:04 PM
lol, I meant if I want to cut something like this:
out of stainless, or should I use a dremal motor?
Old 07-08-2008, 06:45 PM
ok, youve inspired me to change my design, now.. how do I make solid rotational joints? here's My Idea so far for a joint :
hopefully that makes sense (I suck at explaining things.. but if it dosn't make sense I'll try to explain it)
Snk cnc 5axis index milling help? Chris Rees General CNC (Mill and Lathe) Control Software (NC) 0 02-09-2008 08:55 AM
Need Help!- what is the best 5axis software 5axisatm General CAM Discussion 5 02-08-2008 04:52 PM
5axis Help jybute Haas Mills 0 11-22-2006 08:10 AM
NX4 to 5axis DMU80P/HeidenHain530 Jakrro Post Processor Files 1 10-26-2006 04:12 AM
Can I EMC2 to controll 5axis robotic arm CNC? goaII LinuxCNC (formerly EMC2) 2 10-10-2006 12:38 AM
