| Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here. |
I don't imagine everyone around here just cuts wood with thier routers but I want a build that is a bit bigger... here is what I'm looking at Price limit: $15,000 OPTIONS Can cut: pretty much anything steel, real steel 4140 etc Accurate: +- .001 at the worst +- .0001 would be optimum with 2 tenths repeatability Number of axis: 3 minimum, more is better Spindle: R-8 taper or similar rigid and interchangable Cooling: Flood coolant, preferably thru spindle, large circulation system etc. Control: Your choice, but intuitive and easy preferably compatible with everything Style: Gantry or conventional etc your choice Enclosure: Any Max work size: 18" x 14" x and y Tool carriage: Automatic tool change if you can fathom it as many tools as you can fit What you have available -Full machine shop with CNC capability (some what limited) -Access to 2 Haas TL-2's most of the time -2 and 3 axis bridgeport retrofits all you want with mill-power -Limited access to some faddal and some other machines with up to 4 axis and solid works capability. -Precision surface grinders -Tool post grinder etc - Most of the other convetional machine shop tools etc etc... -Lots of free metal for castings -Acccess to free fixturing in aluminum -A furnace capable of casting iron in quantites of 400 lbs per mold -Still don't have advanced mold capabilities however considering building foam cutter for lost foam casting if needed. -Lots of smart people with machining experience -3 old foundry sand crabs If you have any questions about anything else that may be available please let me know. I'm sure there are things I have missed that will need to be brought up... |
| Save your self some time & money......Check this out!! Precision Cast Iron Gantry Machine, travel 16" x 22" x 10" Fagor $5000. control, 3 spindles, AC Servo's.... the works! Ebay #260245066335 Buy it now $4500. didn't sell ( has been listed twice) CMS sells a similar model w/ tool Changer for $28K Cheers. |
| Is this in the right area? Do you want to spend 15k to build something with those kind of tolerances or are you looking to get a machine for that? If it is 18" X 14" then that honestly should be a pretty simple thing especially with a used machine. If it's 18' then good luck. Just the ballscrew itself will not have tolerances of .001 over 18 feet. I hope that you are looking to build a machine because I would love to see it come together. Especially since my budget is much closer to 1/10th of what you are spending. Tim |
| It is customary to start your own thread to ask questions that have nothing to do with the topic you post in. I realize you may be new at posting on Forums and may have French as your first language. Perhaps not. THK 12's is all that would be needed on some machines. Then HSR 55's may not be large enough for others. Feed us a little more info in your NEW thread.
__________________ Lee |
#10
#11
| rather than trying to build a machine that can do what your asking for why not buy a new or used toolroom haas , the machines are cheaply priced and you'll be able to cut steel or whatever reliably and you can have the relief that you didn t shell out 15,000 for something that probably won t do what your expecting
__________________ A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org |
| High Quality Cnc Router | aghobby | Product Announcements & Manufacturer News | 2 | 08-27-2008 05:15 AM |
| High-quality CNC router | ice | Product Announcements & Manufacturer News | 3 | 08-27-2008 04:54 AM |
| Very high precision DIY CNC router? | kenny1 | Open Source CNC Machine Designs | 9 | 02-05-2007 10:24 PM |
| High Z cnc router- opinions? | michaelL | Commercial CNC Wood Routers | 11 | 01-13-2006 08:09 PM |
| Don't forget to check the user reviews | CNCadmin | CNCzone Club House | 0 | 07-08-2004 02:56 PM |
