Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
Old 03-28-2008, 10:59 PM
camcam is on a distinguished road
So Much Noise
I built a CNC about a year back and it has been working great, but, the noise is so intense.
I would have to say it comes from the router head. I am thinking of building a new holder for the router. I do a little work with molds and was thinking of creating the complete mount out of polyurethane rubber. It is going to take a lot of rubber so I was wondering if any one has tried and if it helps.
Thanks!
Old 03-29-2008, 02:24 AM
esm's Avatar
esm esm is offline
esm is on a distinguished road
Can't say I've worked with polyurethane but I've done a fair amount of sound dampening. I would imagine most of it comes from the router, the rest comes from the router transferring vibration to the frame of your machine. Sound is vibrating air. Stop the vibrations, stop the sound.
What's your machine made out of?
To quiet the large compressor in my shop I wrapped the tank with 2 layers of roofing bituthene, then built an enclosure around it out of MDF,bituthene and egg crate foam. I used lots of screws, bracing, wood glue and caulk to seal that puppy and make it impermeable to vibration. (I used to build custom car audio, and probably will again once my machine is built)
Mass is your friend when it comes to sound dampening, do everything possible to securely attach the router to as much mass as possible.
It sounds like a great idea. If only you could plug those darn vent holes in the router.
Post some pics once it's done.
"I've got a long way to go and a short time to get there, We're gonna do what they say can't be done."
Old 03-29-2008, 06:12 AM
ger21's Avatar
Two things you can do. If cutting with 1/4" or smaller bits, the bits will make a lot of high pitched noise while cutting. Using larger 3/8" or bigger bits will get rid of the high pitched noise.
The other thing is to use a variable speed router at the lower speed settings.
Old 03-29-2008, 08:55 AM
The machine is made of MDF. Thinking about rubberizing the two pieces that clamp the router. See pictures.
Thanks!
Name:	M Body.jpg‎
ID:	56570   Click image for larger version
Name:	M Head.jpg‎
Old 03-29-2008, 10:44 AM
ger21's Avatar
As I said, I don't think that's where the noise is coming from, and I don't think it will help. But feel free to try and see.
Old 03-29-2008, 01:25 PM
I will give the 3/8 bit a try. Easy enough to do. I will look into the variable speed routers as well.
Thanks!
Old 03-29-2008, 01:56 PM
esm's Avatar
esm esm is offline
Excellent point ger21. Since your machine is mdf it does a good job of dampening vibration. Having the y axis rails enclosed under the table eliminates most of the chatter from bearing to rail contact (and it looks clean, too!) The plastic(?) housing on your router already does a good job of killing vibration to the machine. If your machine was all metal with a metal router, dampening would be of more benefit to you. If your router is already firmly mounted I'd start with ger21's recommendation.
What about a plexi enclosure over the machine? Hinged on the rear, spring lift gas shocks to lift it.
Old 03-30-2008, 07:55 PM
Hey ESM,
Yea thought about the cover, not only for the noise but to cut down on those airborn lung particulates.
I like the gas shock idea!
Thanks.
Old 03-31-2008, 07:16 PM
CurtisU is on a distinguished road
Could it be worn bearings in the router?
Curtis
Old 03-31-2008, 11:39 PM
This router is new, my old router ended up with a non conductive air gap in the windings. I have to admit it was worked pretty hard. Noise levels about the same between the two. Loud! Have to wear the ear warmers.
Thanks for the reply!
  #11   Ban this user!
Old 04-01-2008, 05:55 AM
BTW, really slick looking machine, good luck finding the source of your noise.
Curtis
  #12   Ban this user!
Old 04-01-2008, 06:00 AM
skip20 is on a distinguished road
Try using a mini mill or mini wood lathe spindle with a belt kit.
The noise is way lower & you can get 3000 RPM out of them.
You can get a HF wood lathe for $100 now, try that spindle.
Check out HOSS mill, GREAT idea's.
I mounted a HF mill head to my table & now getting ready to build the tool charger for it with RPM gauge from Little Machine Shop.
You may need to add a brake on you Z motor with a timed relay to hold the extra weight if you lose power.
keep the noise down! SIMONSIGNS General Electronics Discussion 14 12-04-2008 11:42 AM
z axis noise johnmckeown Fadal 12 12-07-2007 08:13 AM
HELP with the noise becikeja WoodWorking 7 03-08-2007 05:29 PM
servo noise johnmckeown Fadal 3 12-04-2006 12:24 PM
Noise keys DIY-CNC Router Table Machines 10 04-25-2003 01:47 PM
