Results 1 to 4 of 4
Thread: Bedframe design idea
    Mar 2008
    How does this look for a bedframe rails design? I'm trying to do a design as cheaply as possible. I have an old cot frame with a trundle under it that my girlfriend was going to throw out when inspiration hit. Basically the table/x axis frame, gantry frame (movable) and y axis frame should turn out to be 99% free. The only problem I forsee is getting the steppers on either side to sync properly. I know it's not to scale, it's just something I threw together in qcad (yep, another linux user) and to be honest I've never used any cad software before. The way I see it, the gantry will be 28" on all sides with the table itself being 56" overall in length and around 30" to 34" wide. I plan on putting the ganry together first and build out from there.
    I forgot to mention that I plan on using this first one to build a smaller one for pcb's and then on to perhaps a nice aluminum project (I can dream right?).
    Attached Files Attached Files
    Mar 2008
    I just realized that I should have attached a picture too. Sorry about that.
    Attached Thumbnails Attached Thumbnails Bedframe design idea-bearing_table_design.png
    Apr 2007
    Hi, Interesting design. I am also a beginner, so take this info with that in mind.
    a) Stepper motors direct driving the pinion
    - I am (planning ) to do the same thing, and mechmate builds also do that.
    - Keep the pinion rather small to maintain torque from the motor - and don't go for a wimpy motor or it will skip steps under load.
    - There are some various vendor links in my attempt at a build log
    - Getting two motors to sync is not a problem - mach can do this for you, but plan on needing a driver for each motor
    b) Rollers
    - It is easy to draw rollers mounted in a straight line, and really hard to actually accomplish this, especially when you try to constrain the movement of an axis in 3 D
    - You can get some ideas from the linear carriages sold by cncrouterparts.com
    c) Spring Load on the rack and pinion
    - Since the movement is never perfect and rails are never completely straight, it is common to sort of spring load the gear / pinion against the rack. Also a bit of a pain.
    BTW - The frame is the cheap part - the real money is in motors, drivers, and other electronics.
    Apr 2008
    I am a TOTAL noob to all this, but I have to say, I like your creative thinking
    I hope it works well for you!
  1. New Machine Design book from Alexander Slocum (of Precision Machine Design)
    By toastydeath in forum General Metal Working Machines
    Last Post: 11-25-2009, 11:37 AM
  2. Finding Engineering Design Software For Automatic Machine Design
    By hellokitty in forum General CAM Discussion
    Last Post: 01-06-2008, 01:39 AM
  3. design idea.
    By oneturboneeded in forum General Waterjet
    Last Post: 05-23-2007, 02:13 AM
  4. My idea of a spindle design
    By Guldberg in forum Mechanical Calculations/Engineering Design
    Last Post: 10-07-2006, 06:48 PM
  5. Just an idea...
    By Clueless in forum General Metal Working Machines
    Last Post: 09-11-2006, 07:00 PM
