| Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here. |
The attached document is a PDF containing a U S Patent of a machine with 5 Axes. It may give some builders a Idea or 2. Anyone know the software needed to generate code for this type of machine? |
| I have already seen a machine like this built prior to the patent, but you can change one little thing and get a patent, this one has a lifting z-axis which is slightly different than the one i had seen before. Joe |
| Hello Clockwork, You need a specific 5 axes post-processor customized for your machine to generate the right trajectories (depending on contact point absolute coordinates, tool orientation, tool length, tool radius,... ). |
| I'm new to forums, but I have a question: Can't the LinuxCNC program handle any 5 Axis cutting? It supports moving up to 9 axes simultaneously. http://www.linuxcnc.org/content/view/11/10/lang,en/ Last edited by Athlon64M; 05-25-2008 at 11:43 PM. |
| Absolutely. EMC can handle five or six axis machining. The problem isn't running the program; it's writing the program. A good CAM program will do that for you. Ken
__________________ Kenneth Lerman 55 Main Street Newtown, CT 06470 |
| Oyeah forgot to include this in the last post. Free 5 axis cam http://www.rainnea.com/cnc_toolkit.htm |
#11
| Well I am not going to built a 5 axis but thank you a TON! cause you just gave me a nice way to get the 4th axis done on my machine finally. This plan gave me what I was looking for for the spin axis. Thanks from the top of my bottom!!!! Coog
__________________ Building Stage:[xxxxxxxxxxxxxxxxxxxx] 105% Finishing Stage:[xxxxxxxxxxxxxxxxxxx-] 95% |
| 3 projects of CNC Router 3Axis, 4 Axis and 5 Axis | LuthierX | General Metal Working Machines | 11 | 07-06-2008 08:26 PM |
| 3 projects of CNC Router 3Axis, 4 Axis and 5 Axis | LuthierX | General Metal Working Machines | 0 | 02-25-2008 09:12 AM |
| 4th axis on my router | ronnieman | CNC Wood Router Project Log | 10 | 03-18-2007 06:35 PM |
| New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter | the__extreme | CNC Wood Router Project Log | 3 | 02-26-2007 02:58 PM |
| z-axis router help help | camfambmw5 | DIY-CNC Router Table Machines | 0 | 10-09-2003 09:05 PM |
