| Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here. |
i did a search an could not come up with a answer i liked. I am starting to build my first cnc. 36" x and y lead screws, 4" z leads screw 1.75 hp PC router. proballt 350 in/oc steppers. I am wanting to do a over head lead screw on the x and have the x rail up lust below the y axis. i want this so the cnc can be placed on somethign and cut into it, such as flooring. I will also build a vacume table for it to sit on. I plane on using 1 1/16" chrome hafele closet rod for the x and y rails. this stuff is over 1/16" wall thickness and super smooth. I have a nesting router cnc a work to cut my parts. here is my idea. can i cut half circles out of 1" thick derlin and use it for slides? i would run 2 on top of the rail, about 6" apart, and then one under neith between then, tighend up just to barely touch so the gantry cant lift off the rails. WIll these be smooth enough? i am not looking for a super fast cnc, and it really only needs to be acurate to about 1/32 of an inch. This seams easier then building the carts with scate bearing, though i cna do that too. On a side note, i bought my z axis with a stepper attached and can see how to get the lead scerw off. are they pressed onto the shaft? could i get it off with a blow torch and heating it up? thanks in advace |
| i would be concerned the delrin will get distorted with the constant weight on them , what i used on my first machine was oil impregated bushings which worked well ,they are cheap and may be an alternative
__________________ A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org |
| But there is a minor problem which could affect a machine under a heavy load. When the Delrin bearing is stationary for several days, and especially if the temperature changes up and down, it seems to 'settle in' and you have to put use extra force to get it moving. Once it has been moved it goes back to the original torque.
| thats good to know ive concidered using it for a slide assembly in the past but ruled it out due to the concern of distortion by weight and forces from cutting i had some delrin bushings kicking around ,where they are now is beyond me , the stuff slides beautifully and a little oil makes it pretty slick , if it is that stable then i would imagine it would work much smooter than the oilite bushings i had used
| UHMW vs Delrin vs HDPE rail slides | Rance | DIY-CNC Router Table Machines | 15 | 01-03-2009 03:16 PM |
| Linear Slides v/s rail slides | bryanrabb | DIY-CNC Router Table Machines | 4 | 03-27-2006 08:45 PM |
| Slides ? Whats that? | JohnnyYuma | DIY-CNC Router Table Machines | 4 | 03-22-2006 09:15 PM |
| Where to buy THK slides | georgebarr | Linear and Rotary Motion | 10 | 12-13-2005 08:02 AM |
| Rebuilding THK slides? | space_case | DIY-CNC Router Table Machines | 2 | 09-13-2005 08:15 PM |
