Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
Old 09-24-2007, 10:13 AM
Clockwork is on a distinguished road
Easy Method to Zero the Z Axis
I came up with this idea a few weeks ago.
Spray a tiny shot of spray glue on a small strip of aluminum foil.
Press foil on one corner of the wooden blank leaving some of the foil dangling over the edge.
I use a cheap multimeter with a continuity buzzer to perform the calibration. Just about any continuity tester will work. You can also make your own with a LED + resistor + battery or Buzzer + battery.
Attach one alligator clip to the dangling foil and the other to the bit.
Lower the z axis slowly until continuity occurs.
The Z axis is at now at zero.
This should be good enough for woodworking - you can always mic the foil and add the difference for greater precision.
Comments?
Old 09-24-2007, 11:05 AM
jimini is on a distinguished road
A couple of years ago Balsaman had a superb idea, based on the same procedure, I believe he used it as sort of a limit switch to find zero.
Old 09-24-2007, 11:31 AM
With this idea, you'll need to have your Z home to top of work piece.
Check this:
http://www.cnczone.com/forums/showth...saman+set+zero
Old 09-24-2007, 11:47 AM
tahustvedt is on a distinguished road
I made a connector on the gantry for the limit switch circuit and use an aluminium plate and a crocodile clamp to create a circuit as the tool is jogged down slowly. As the tool touches the aluminium plate the limit is toggled and it stops and I get an accurate height with all my tools. Once the tool touches the plate I type in the thickness of the plate in the Z-coordinates ont he screen.
Before I made the limit switch cable I used an ohmmeter to check for contact as I lowered but that was tedious and more manual compared to just lowering until it stops by itself.
Old 09-24-2007, 03:55 PM
Glidergider is on a distinguished road
If you are using Mach3, there's even a better way then those mentioned above. I'll find the link and post it here if you want it. Maybe you've already seen it?
Old 09-24-2007, 03:56 PM
Here it is for all you Mach3 users. It's the best way to zero your tool.
http://www.cnczone.com/forums/showthread.php?t=36099
What method did you use to move the x-y-z axis? widgitmaster Polls 4 01-07-2008 01:35 AM
Easy CNC and Easy Stepp'n kylecroft CNCzone Club House 5 02-18-2007 11:54 AM
What method will be more accurate? DennisCNC Mechanical Calculations/Engineering Design 9 09-01-2006 05:44 PM
Best method to make this Moondog General Metal Working Machines 14 10-07-2004 05:49 AM
Best Method musky2much WoodWorking 1 10-13-2003 08:59 AM
