Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
Old 09-18-2007, 12:42 PM
cueshark is on a distinguished road
acme screws
i am wanting to know the difference it will make other than speed between 5/8x6 acme & 1/2x10 2 start? i can buy the 5/8x6 for $$13.99 for 6ft. the 6ft of 1/2x10 2start cost me $53.11. i am just trying to see if the cost differance is worth it? i can get 1"x5 acme for $20.29 for 6ft. i have a small mill & a 13x40 lathe so i can make my on plastic selfadjusting nuts. thanks fo any info any one can give me. greg
Old 09-18-2007, 02:59 PM
Coogrrr's Avatar
Coogrrr is on a distinguished road
well I dont know much but..
The 6 or the 10 is what is going to make the diff here. the more turns per inch gives you more resolution as in 200 steps per revolution x 10 revolutions per inch = 2000 resolution or .002 rather. If your not worried about this resolution like a strict wood machine only doesnt need this much usually then the last part is the whip factor.
With 1/2 inch thick acme you can get longer lengths to move faster with less whip. So 5/8 should in effect whip less but would have less resolution. I would not use either of these at more than 48" unless you slow it way down.
That all being said... I would go for the less costly if you can get supports/bearings/anti-backlash setup on that size (5/8). There is a ton developed around the 1/2" stuff but I would think that you can find items to fit your needs at 5/8 also.
anyone else???
Coog
Building Stage:[xxxxxxxxxxxxxxxxxxxx] 105%
Finishing Stage:[xxxxxxxxxxxxxxxxxxx-] 95%
Old 09-18-2007, 05:36 PM
mactec54 is on a distinguished road
Hi Cueshark
The 1/2 10 acme 2 start is ok as long as it has good support and not to
long the 1/2 10 acme 2 start will move 5 turns per inch not 10 turns per inch as said in the last post .200 per turn
Mactec54
Old 09-18-2007, 10:05 PM
Coogrrr's Avatar
as Mac says it is 5 turns per inch the 200 steps x 5 would equal a resolution of .001 then still pretty sharp for wood working. Thanks for the clarification Mac.
Coog
CNC conversion w/ acme screws magma-joe Bridgeport and Hardinge Mills 3 07-08-2007 07:21 PM
Acme Screws 4-Sale compmedic General Metal Working Machines 4 06-18-2007 09:26 PM
Ball screws, Acme screws, threaded rod DJ Morrow DIY-CNC Router Table Machines 11 03-22-2007 12:39 PM
Max RPM of 1/2" ACME lead screws? Tom Brown Open Source CNC Machine Designs 3 09-11-2006 01:34 PM
ACME Screws in the UK TonyWood DIY-CNC Router Table Machines 9 11-30-2005 03:23 PM
