Results 1 to 2 of 2
Thread: Z axis amplitude
    Mar 2004
    Z axis amplitude
    How much Z-axis amplitude do you suppose is reasonable? I've been looking at 48"x24"x6" as a goal but the more I think about it, the more I wonder if I will ever use more than 2" of z-axis. I'm pretty sure I don't need that much X & Y, either.
    I assume these machines spend their lives working on flat stock of 3/4" dimension and less.
    Why would you ever want more than 2" of z-axis travel?
    Mar 2006
    NC, USA
    Changing bits or loading material is easier if its higher, I have to be able to pull off my dust collecting hood to access the collet. I had a goal like yours but ended up with 18"x32"x5" work area, footprint dictated the size in the end.
    To have 6" of usable Z travel along the whole table you'll need to keep an eye on your carriage height.
  1. A 5-axis CNC machine including a rotary axis
    By synthetiklone in forum CNC Wood Router Project Log
    Last Post: 07-30-2012, 05:43 AM
  2. the Difference of 2-Axis and 3-Axis of Vertical Mill Machine
    By begacon in forum Knee Vertical Mills
    Last Post: 07-30-2009, 07:31 AM
  3. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 03:58 PM
  4. Options for 2 Axis Head (to make 5 axis)
    By drewgarth in forum DIY CNC Router Table Machines
    Last Post: 07-12-2006, 01:37 AM
  5. Frequency vs amplitude of the vibration for a polisher
    By jkeyser14 in forum Mass finishing equipment/media/stratigies
    Last Post: 12-25-2005, 06:03 PM
Visitors found this page by searching for:
Nobody landed on this page from a search engine, yet!
SEO Blog
