Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
Old 04-11-2004, 11:23 AM
Wanna be
Hack is on a distinguished road
Looking for people wanting to develop new plans for a cheap cnc
While reading this site and a couple of threads in particular, I think it is obvious that most / all people here are interested in a set of nice and thorough plans for building a cheap cnc router, or converting a mill or lathe to cnc. Obviously these plans should be suited for the beginner with minimal tools and use readily avialable materials either locally or over the net.
I would be interested in getting together a few of this site's gurus together to develop these plans. I am by no means a cnc guy, but can offer some cad work and good writing skills to help with the actual plan development. I need people with the technical knowledge to help.
Any interested parties, please reply with comments, suggestions, etc.
Dan
junkmailacct@sbcglobal.net
Old 04-11-2004, 01:01 PM
owhite is on a distinguished road
Hack,
I hear ya. I think it'd be a shame if we couldnt get together some drawings for new people to at least get a general idea of what's going on.
I do a lot of cad drawing, and have built three tables. feel free to contact me if you think there's some way I could help.
owen
owhite@tigr.org
Old 04-11-2004, 02:01 PM
ehiebert is on a distinguished road
I would be interested to help out with a plans set. Probably the most confusing to a new hobbyist is the electronics. So I would contribute to that section.
I am just starting my own router design and will be developing a unipolar driver board employing the Allegro chipsets.
Their best micro-stepping PWM drive can do 36 V at up to 3A per phase. I will be building an opto-isolated 4 axis driver with limit and home switch inputs. The board has onboard current limit adjustment and LCD display of the current limit setting via a PIC ucontroller and 2 line LCD. I already have the schematic designed, but I need to get some boards made and I am waiting for chip samples. Allegro seems to be rather tight fisted with their chip distribution, which is a problem for small volume buyers like hobbyists.
Eldon.
Old 04-11-2004, 03:42 PM
teilhardo is on a distinguished road
I'd like to contribute to some CAD drawings. I am somewhat of an amateur, but I can do most 2d operations and some 3d operations. But hey, anything that I can help do is practice.
I also think that the electronics are a good idea. Basic schematics, info on stepper motors and a glossary of fairly common terms would al be a plus
-Tei
teilhardo@yahoo.com
-Please check out my webiste-
http://www.teilhardo.com
Old 04-11-2004, 04:14 PM
pminmo's Avatar
pminmo is on a distinguished road
I agree with the goal. I started designing my own and that has evolved as I have built. My suggestion is cheap and available. Along the klingenberg (sp) lines, using roller blade bearings (common, different grades different prices, but inexpensive in comparison to precision rails an bearings). While I'm pursuing a moving gantry, I would recommend a fixed gantry for those with limited budget and tools, and if I were to start over it would be a fixed gantry with a 42" Y axsis and a 18" Y, using steel pipe on the y, roller bearings on the x, and mdf as a construction material.
Let me know what I can do to help, but at this point I'm well into the learning phase, not an expert.
Phil
Old 04-11-2004, 04:51 PM
I forgot to mention that I don't think I can be to useful on the design side. I have not had the "pleasure" of building my own DIY router, I am the happy owner of a CNC taig mill. But I am planning to build a router. I thik that Pminmo has good ideas on what type of materials to use though.
Old 04-11-2004, 06:22 PM
pminmo's Avatar
I think Balsaman had some of the right idea, and what I was referring to as a fixed gantry here :
http://webpages.charter.net/pminmo/rec0.jpg
I think by making the y longer with open ends (i.e. +/- a couple of inches so long pieces could be routed)
Incorporating bearingsetups such as xairflyer and Jer21:
http://webpages.charter.net/pminmo/rec1.jpg
http://webpages.charter.net/pminmo/rec2.jpg
http://webpages.charter.net/pminmo/rec3.jpg
is there way I would go if starting over.
Pminmo
p.s. I have a simpler driver design I'm going to post when I get a chance.
Old 04-11-2004, 07:44 PM
well, looks like we have people that would contribute to the drawing. s'what should get drawn up? I think its about picking a particular design and then going at it, perhaps with emphasis on all the variations that could be made for each part. It'd also be helpful to elect a general manager that was looking at the drawings and putting in requests for what other designs would be required.
Old 04-11-2004, 07:45 PM
vacpress is on a distinguished road
i would say count me in, but i am working on some similar ideas indipendantly - however, i would love to compose a "book cover" for the thing, or a "Style sheet" that would be a template for you guys.. something along the lines of what i put in my "18 page machine design" in the opensource cnc file section.
i like the idea of it being a "cnczone.com" planset, so it would either be free, or come with a $5 donation to the site, or something.. i really like some of the MDF routers here -they look good, and probably work well.
maybe a good place to start would be digging around and everyone comming to a consensus on what ideas work best in terms of leadscrews, linear guides, motor boards, etc.
i think the allegro chips are to hard for a beginner to solder... some sort of pic-driven H-bridge bipolar might be best in terms of ease of assembly and cost.. the hudle there is programming the chip.. but at least microchip.com is very generous with samples.. ive got 25 pic chips in nice little cases from ordering samples over the last year.. you can request 5 of their top-of-the-line $20 chip, and get them a week later for free....
Design & Development
My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
Old 04-11-2004, 07:47 PM
maybe offering a blank PCB with the programmed PIC chip for $15 per axis would be reasonable? and the h-bridge idea means high-current.... i know there are some opensource boards out there like this...
  #11   Ban this user!
Old 04-11-2004, 07:52 PM
I like where vacpress is going. And I'm thinking it would help to break up the project into bite-size chunks. One person handles the base, another the gantry, another the z-axis. Opinions?
Old 04-11-2004, 08:14 PM
Wanna be
Ideas for these plans
I think in my mind that since this is going to be a group effort, that perhaps no one should really profit from the design work, and that maybe these plans don't need to be in print so to speak but hosted on CNC Zone. If we could get some input from CNC Admin that would be great. If we could provide these for a small fee downloadable in say PDF format or something with the proceeds going to the site to help cover bandwith, storage space etc.
Any other thoughts?
Dan
Help to choose CNC Router Plans. Moondog DIY-CNC Router Table Machines 4 01-20-2010 02:50 AM
Simple cheap CNC router mwalach DIY-CNC Router Table Machines 7 10-28-2005 08:08 PM
Cheap Circuit Board CNC Machine? Ian Cunningham Europe Club House 7 03-02-2005 10:31 AM
Cheap CNC, eh? ;) Zippi DIY-CNC Router Table Machines 4 09-11-2004 08:05 AM
Cnc Router table Plans and ideas ljoe1969 DIY-CNC Router Table Machines 23 11-13-2003 09:12 AM
