Results 1 to 6 of 6
Thread: How to drive double x-axis?
    Mar 2007
    Holland
    Hi all,
    I am currently building my first cnc machine.
    It has two x-axis (THK KR4610-840) both driven by it's own stepper motor.
    How do I connect both motors correctly so that they will work identcal?
    Do I need two drivers? I guess so. Or one "heavy" driver?
    Can I connect two (optical isolated) drivers directly to the same pins of the LPT port? Or do I need to control them seperately in the software (mach3)?
    I did find almost all info I needed on his great site, but could not find the answer on this one.
    Thanx for helping!
    ps I have tried two attatch a picture of the design but I need an URL for the image....????
    Mar 2003
    Shelby Twp, MI....USA
    The answer to most of those questions is yes. But the best way, imo, is to use 2 drives and slave the two motors in Mach3.
    Dec 2006
    canada
    Smile
    Quote Originally Posted by zone023 View Post
    Hi all,
    Thanx for helping!
    electricy like slaves revolt,take a brake ,or just die, i would like to see you couple both axiz with a shaft and gear,and use one motor,a word from some one whom has done it
    May 2006
    I have done it. Very successful so far.
    Separate drives are almost essential. Notice I said almost. One Gecko can drive two matched steppers. I wouldn't.
    You can connect two drivers to one set of pins on the LPT
    Slaving them in Mach is better and allows you to have separate homing switches on each side of a gantry for instance.
    That can be an essential item. Depends on your design.
    You can attach a jpeg with "Manage Attachments" so long as it is not above the size restrictions.
    Why don't you try that so we can have a look.
    Greg
    Oct 2004
    Thumbs up
    Quote Originally Posted by ger21 View Post
    This is exactl what I did and it worked perfectly.
    Please check out my CNC blog
    http://cncinside.com
    Mar 2007
    Holland
    I will use two drivers and try to slave them in Mach3.
    This means I have to connect the driver as a 4th axis on the LPT port, right?
    I believe I have attatched an image...
    As you can see I am going the easy way. I had access to 3 THK KR4610-840linear actuators.
    This makes it possible to get familiar with CNC control without starting with a complex design.
    This is a prototype made of wood, an aluminium construction will be made when I get this one working.
    Thanx for the answers.
    Attached Thumbnails Attached Thumbnails How to drive double x-axis?-cnc_router_plan.jpg
    1. hurco km-1 Z axis drive ?
      By D.D.Machine in forum HURCO
      Last Post: 01-10-2007, 08:19 PM
    2. C Axis Drive
      By Enteralterego in forum Fanuc
      Last Post: 11-09-2006, 04:54 AM
    3. Z Axis Drive Fault
      By jeremy_d in forum Servo Motors and Drives
      Last Post: 08-15-2006, 11:04 PM
    4. Y axis rail- single or double?
      By Corvus corax in forum Linear and Rotary Motion
      Last Post: 11-15-2005, 07:42 PM
    5. Double X-axis Drive
      By mícheál in forum DIY CNC Router Table Machines
      Last Post: 11-15-2004, 09:48 AM
