Results 1 to 3 of 3
Thread: Diy - Vfd
    Registered Coogrrr's Avatar
    Dec 2006
    Diy - Vfd
    I want to control my router and later my spindle with a VFD(is this the proper thing) but I would like to make my own.
    Does anyone have a thread here or a link to some plans?
    Thanks in advance
    Coog
    Building Stage:[xxxxxxxxxxxxxxxxxxxx] 105%
    Finishing Stage:[xxxxxxxxxxxxxxxxxxx-] 95%
    Jun 2006
    You need to get whatever matches the type of motor you will use.
    Your router motor is a universal motor, there are speed controllers made for these. Cannot use a VFD for this.
    VFD are typically for 3 phase ac motors. If your spindle is going to use this type of motor then yes, a vfd can be used to control speed.
    Dec 2006
    Thank you for the info!
    I will search for a good speed controller for my router then. I want to be able to use mach3 to control the router speed.
    Coog
