Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
Old 02-03-2007, 09:14 PM
avisnofsky is on a distinguished road
Question about steppers...
A while back I acquired 3 Vexta PK245 steppers. These motors have 61 oz-in holding torque. Will they be enough to drive a 4" machinist vise for use with PCBoard milling? Will I have to connect them to the leadscrew via gears? Any help is appreciated.
Old 02-03-2007, 10:18 PM
Konstantin's Avatar
Konstantin is on a distinguished road
Probably will be enough. Maybe some gears (timing pulleys more likely) to increase resolution, its up to you.
What resolution are you aiming at? Full/half/micro step drive?
Are the motors Bipolar/Unipolar, 2 phase or 5 phases?
Konstantin.
Old 02-04-2007, 11:30 PM
Im not sure what resolution. What kind of accuracy do you think I could acheieve? I will be running the motor in unipolar mode (its 2 phase). The motor is 1.8 degrees per step. Thanks for the help!
Newbie question on steppers Galdrin Stepper Motors and Drives 5 06-09-2010 11:03 AM
question on steppers bru CNC Wood Router Project Log 1 12-23-2006 05:57 PM
Steppers and resistor-question. viktorcnc Stepper Motors and Drives 10 04-05-2005 03:38 PM
all electronics steppers question mhackney General Electronics Discussion 2 02-22-2004 08:36 PM
Copy machine steppers question Darren_T DIY-CNC Router Table Machines 2 12-01-2003 03:25 PM
