Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
Old 01-29-2007, 04:37 PM
jsage is on a distinguished road
Polymer enhanced Concrete Work Area
Concept
I realize there is whole thread on this but here is my concept.
Preliminaries
Concrete the new cast iron
Strength is based on reinforcement, aggregate choice, minimizing water content, enhanced by cross linking with Epoxy. Also the fiber content, virgin nylon can enhance characteristics.
My general feeling is provide good structural reinforcement. In this case the vacuum piping is a structural component with of course steel pipe.
There is also room for rebar below. Thickness about 2 1/2 inches. This is one panel there will be two. Reason longer sections will be more prone to cracking.
Each section has two vacuum ports.
Again this is a concept so I expect revisions.
I've done a bit of work with epoxy and with concrete. I don't believe you have sell the farm on polymerizing content, i.e spend a fortune on high end polymerized concrete. Time will tell. Also I purchased an air hammer for $14 which will aid in removing air.
One other thing, not much experience with these things but I expect you could plug unecessary wholes in a recessed manner. Similarly the the holes can be used with bench dogs.
Name:	polymer concrete base section w Vacuum piping.jpg‎
Epoxy-Granite machine bases (was Polymer concrete frame?) walter Epoxy Granite 4640 05-17-2012 04:20 PM
Polymer Concrete ericdwilso General Metal Working Machines 10 09-14-2009 01:00 PM
120x240cm(work area) Router Table - steel/aluminium Goose80 DIY-CNC Router Table Machines 9 12-13-2006 03:43 PM
Looking for work in Lake Havasu City Area VanCam Employment Opportunity 1 11-26-2006 03:04 PM
Looking for work in N.C. area gv71 Employment Opportunity 0 01-22-2006 09:30 PM
