Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
Old 01-23-2007, 04:57 PM
Nic Scheepers is on a distinguished road
Minertia Ugfmed
Hi there,
Can anyone tell me what the encoder wire connections should be. I looked on the yakawa site and could not find the specific motor with the color of wires.
Black
Blue
Orange
White
Brown
Purple
I want to use it to drive my leadscrew for normal turning so that I do not have to change the gears, I want to put a normal PWM controller on it but have a LCD screen readout for the speed and maybe the distance. Is this feasible? Or should I put a stepper motor on it?
Old 01-30-2007, 09:56 PM
faststeve is on a distinguished road
I'm going to be using those motors with Larken Viper drives. Ordered them last week. The guy at Larken said they work great with his drive. He said the powersupply should be about 30 volts for that motor. The encoder is 1000 lines I think.
http://www.larkencnc.com/viper/index.shtml
Old 01-30-2007, 11:39 PM
Thanks ,
I will drop them an email.
Regards
Nic
Old 01-31-2007, 10:28 PM
routerman is on a distinguished road
The encoders on my Minertia motors are 2000 lines or 8000 in quadrature.
http://cgi.ebay.com/ws/eBayISAPI.dll...ype=osi_widget
They run good on my controller with viper drives. Very powerful little motors
Old 02-01-2007, 12:30 AM
Hi there,
I had a look again last night. The power cables seem to be the purple and the brown(The wires accross the capacitor) wires but I could not get any response on my scope from the decoder. Maybe it is broken or I had the wiring wrongly.
Regards
Nic
Old 02-02-2007, 11:45 PM
To find the power wires for the encoder, remove the cap to expose the pcb. Find a IC and usually the top right pin is +5V and the bottom left is Gnd
Use a meter (in condinuity mode) to find which of the output wire connects to these pins on the chip. Once you find these, apply +5V power and use a scope to look for the pulses from the encoder as you turn it.
Old 02-04-2007, 11:41 PM
Hi there,
Thanks, this sounds more defintite. I will try tonight and give feedback.
Regards
Nic
Yaskawa Minertia motor connections belli Servo Motors and Drives 7 01-28-2007 11:35 PM
