Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
Old 01-22-2007, 10:35 PM
kenny1 is on a distinguished road
Will this stepper work?
Last summer I bought some stepping motors at a local flea market.
These are eight wire 2 phase 6 volt motors, and their labels say on them 'Vexta Stepping Motor Model PH266M-E1.2'. These have a four bolt mounting pattern about 47mm center to center and a 6mm shaft.
Will these work for an axis drive motor, and if so where can I get a controller to run these?
Thank you,
kenny1
Old 01-23-2007, 12:35 AM
Lionclaw's Avatar
Lionclaw is on a distinguished road
Couldnt' find a datasheet, but it looks like someone else paired it with a Gecko driver. I believe with 8 wires you can wire it for unipolar or bipolar.
http://www.luberth.com/cstep/myhardware.htm
Andy
CNC Kits - http://www.comptonsoft.com/cncweb/
Old 01-23-2007, 03:00 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
those motors are probably around 100oz-in unipolar, this is the new substitute for that motor which is normally more powerfull than the one being replaced
PK266M-E2.0A
PK266M-E2.0B
Bipolar (Parallel)166 oz-in
Bipolar (Series)166 oz-in
Unipolar 127 oz-in
Old 01-23-2007, 05:07 PM
I can see why the ones luberth.com used got hot - it's sorta expected when you power a 6 volt motor with 60 volts.
I went to orientalmotor.com for more information, and the website said there is no info on these because they are discontinued. These steppers have a weird wire color code - black, yellow, red, orange, and then the same colors striped on white wires for a total of 8 wires. I want to use these bipolar if possible, power is no problem.
I am going to try these on a Z axis and see what I get.
Thank you,
Kenny1
Old 01-23-2007, 08:30 PM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
the recommended voltage is 20 - 25 times the motors voltage, 10 times the voltage is no problem at all using a modern chopper drive
Old 01-26-2007, 12:17 AM
I didn't know that you can put so much voltage into a stepper, I have so much to learn.
Where can I find out how much stepper torque I will need for each axis of a machine? I want to use one of these steppers for the Z axis, maybe one for the
Y axis and two for the X. My machine will be roughly 18"x24" or 18"x36"
Thank you,
kenny1
Old 02-03-2007, 05:45 PM
ghimpe--'s Avatar
ghimpe-- is on a distinguished road
Hello.
I have some 6 wire stepper motors from some old printers. Model: STP-57D101-01, 1,8DEG/Step 3.6V 0.8A.
If i understood corectly from the above posts it should be safe to power them with a much higher voltage. I was thinking 24V. Is this safe or I missunderstood.
And what are the implications in over powering a steper motor? Will it rotate faster? Will it have more power?
Sorry for such noob questions but i'm new to stepper motors.
PS: Realy nice forum, i'll stick here for a while hoping to make me an wood 3 axis CNC.
Old 02-05-2007, 01:33 AM
dertsap's Avatar
Gold Member
heres a wiring diagram i think should match up for your motors
Old 02-05-2007, 11:06 PM
Thank you dertsap, your diagram is the exact one I needed. I had given up looking for the info, and Oriental Motor wouldn't give me one.
Definition of the word 'bummer'... the guy I bought my motors from had lots of them, and I got his phone number. Now I can't find it.
Kenny1
Old 02-06-2007, 12:06 AM
dertsap's Avatar
Gold Member
oriental motors doesn t give out info if the motors are specific to one product or company
i've tryed before , and their reply was to check with the company which produces the product the motor came out of
  #11   Ban this user!
Old 02-08-2007, 12:05 PM
ghimpe--'s Avatar
Could somebody please answear my question posted above? Please!
It's nice to be important but it's more important to be nice!
  #12   Ban this user!
Old 02-08-2007, 12:28 PM
Jason Marsha is on a distinguished road
Originally Posted by ghimpe-- View Post
Hello.
Yes you can use 24 volts without a problem. Steppers are powered with 15 to 20 times the their rated voltage. So even if you go up to 36 volts you will be fine. The key is not to exceed the rated current.
Jason
Will this stepper work BeerFizz DIY-CNC Router Table Machines 5 04-26-2008 04:53 PM
dave, How is 23-200-DS8 Unipolar Stepper 8 wire work? cjchands Hobbycnc (Products) 2 10-16-2006 12:37 AM
difference between a stepper indexer and a stepper drive pcroxford Stepper Motors and Drives 0 11-02-2005 08:35 AM
Servos on x/y - Stepper on z - will it work? WoodSnarfer Servo Motors and Drives 8 11-16-2004 07:12 PM
Will These Work (Stepper Motors) Hawkeye DIY-CNC Router Table Machines 9 12-06-2003 12:53 PM
