Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
  #13   Ban this user!
Old 02-09-2007, 01:37 AM
ghimpe--'s Avatar
ghimpe-- is on a distinguished road
Thanks Jason for your reply.
"The key is not to exceed the rated current."
They are 0.8A, so i'll have to limit them to not draw more than that? I'm not sure i know how to do that, but i'll google arround.
It's nice to be important but it's more important to be nice!
  #14   Ban this user!
Old 02-09-2007, 08:21 AM
Jason Marsha is on a distinguished road
When you are ready for the electronics you can try hobbycnc.com.
I bought my first stepper drivers from them and they are excellent quality.
Jason
  #15   Ban this user!
Old 02-10-2007, 09:11 PM
kenny1 is on a distinguished road
I get it now... You can raise the volts to the stepper as much as you need to, just as long as you don't exceed the stepper's rated current draw. But, you would think that the higher volts would increase the stepper's speed but decreasing in amps to compensate for the higher volts would lower the available torque.
Kenny1
  #16   Ban this user!
Old 02-10-2007, 09:30 PM
Madclicker is on a distinguished road
You increase the voltage to increase the speed at which the current rises in the motor coil. This increases the speed at which the motor will run without stalling. You limit the current to what the motor rating is, regardless of what the voltage is.
You don't want to supply over about 20X the rated voltage or needless motor heating can occur.
Steve
DO SOMETHING, EVEN IF IT'S WRONG!
  #17   Ban this user!
Old 02-10-2007, 10:45 PM
I wonder... is there a way to keep the motor cooler? I saw vacuum tubes once in a ham radio with clipon cooling fins on them to dissipate heat.
Ken
Old 02-18-2007, 07:29 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
Ken
if you have a surplus type store nearby you can use pc type of fans and mount them over the motor , ive got a surplus store nearby and bought a wack of em for my drives and motors
  #19   Ban this user!
Old 02-18-2007, 10:32 PM
kreutz is on a distinguished road
Hello.
I have some 6 wire stepper motors from some old printers. Model: STP-57D101-01, 1,8DEG/Step 3.6V 0.8A.
If i understood corectly from the above posts it should be safe to power them with a much higher voltage. I was thinking 24V. Is this safe or I missunderstood.
And what are the implications in over powering a steper motor? Will it rotate faster? Will it have more power?
Sorry for such noob questions but i'm new to stepper motors.
PS: Realy nice forum, i'll stick here for a while hoping to make me an wood 3 axis CNC.
It is safe only if you have a current limiting controller (Resistive or Chopper type), Otherwise you will trash them. They will overheat and saturate magnetically, could also demagnetize the magnets.
  #20   Ban this user!
Old 02-19-2007, 05:11 AM
ghimpe--'s Avatar
kreutz, i've been looking on the internet for DIY choppers. When i will finaly make one, i'll post it here, but that could take some time, i'm realy busy right now and it seems that i'll be even more busy in the next couple of months.
  #21   Ban this user!
Old 02-19-2007, 06:55 AM
Read this thread: http://www.cnczone.com/forums/showthread.php?t=25361
Will this stepper work BeerFizz DIY-CNC Router Table Machines 5 04-26-2008 03:53 PM
dave, How is 23-200-DS8 Unipolar Stepper 8 wire work? cjchands Hobbycnc (Products) 2 10-15-2006 11:37 PM
difference between a stepper indexer and a stepper drive pcroxford Stepper Motors and Drives 0 11-02-2005 07:35 AM
Servos on x/y - Stepper on z - will it work? WoodSnarfer Servo Motors and Drives 8 11-16-2004 06:12 PM
Will These Work (Stepper Motors) Hawkeye DIY-CNC Router Table Machines 9 12-06-2003 11:53 AM
