Page 1 of 2 12 LastLast
Results 1 to 12 of 17
Thread: Fab@Home 3D Printer
    Jun 2003
    Quebec, Canada
    Fab@Home 3D Printer
    I hope this is in the right section?
    Saw this and wow!
    an open source 3D printer that costs just $2,400. The self-assembly kit is part of what they call the Fab@Home project. Finally, rapid prototyping made affordable!
    http://www.newscientisttech.com/arti...volution.html#
    http://www.fabathome.org/wiki/index.php?title=Main_Page
    http://web.mae.cornell.edu/ccsl/temp...bDemoMovie.wmv
    William Desrochers - Excalibur Creations & Recognition
    Raster Bitmap to Vector Conversion Service
    Jul 2006
    uk
    What can you say? – Wow - I guess says it all.
    Registered Coogrrr's Avatar
    Dec 2006
    did some youtubing
    I saw these videos on youtube.com and was agreeing WOW and its also a future project. I make lots of things out of plastic and after a cnc stepper project I will have much more knowledge and the ability to make the parts.
    Building Stage:[xxxxxxxxxxxxxxxxxxxx] 105%
    Finishing Stage:[xxxxxxxxxxxxxxxxxxx-] 95%
    Dec 2006
    I want one please?
    wow is right. I'm drooling now. Blender3d exports .stl files. David 3d scans objects, and now this.
    Pass the drippy drool cup
    Dec 2006
    leave me out
    I'll pass - I still do things the hard way.
    Dan
    Jul 2005
    I have been scoping this for a while. Has anyone made one of these or seen 1? I want to make 1 but have not had any free time.
    Cutmore
    Dec 2006
    Havent seen anything but the vid...
    BUT!!! for us CNC DIY'ers I was thinking... could i place an additional small stepper to push plunger down to excrete the silicone drop. move the X and Y to next spot on the second layer raise the Z and repeat the silicone drop pattern again and thus build upwards to full height of Z a silicone item as they did it?
    Meaning - could we adapt a tool onto the Z axis to in essence make a reverse cnc path for Z and build something rather then cut it down?
    thoughts?
    I will work on some thoughts on this too.
    Jul 2005
    replace spindle with extruder
    You probably could just replace the spindle on a 3 axis machine with an extruder and run your file. I don't know how the software of the fabber works yet but sounds do-able with any of the routers or mini mills out there.
    Dec 2005
    Are there any free plans to download this?, or is it basically you buy the kit which is too expensive.
    Registered Regnar's Avatar
    Mar 2006
    Oracle its a little hard to navigate his website but all of it is there for free. The plans and software. It really looks like if you have a router table you could in sence could build this pretty cheap with only having to buy the electronics and material. Also I think you could convert your 3 axis router as well. Just take mach3 and goto the last line of the gcode-hit run from here-reverse-start. The onlything that I would worry about is some of the cams that are outer there have a hard time doing undercuts and hollow areas. So you might have to build your model in layers rather that just one peice.
    Mar 2003
    Shelby Twp, MI....USA
    Quote Originally Posted by Oracle_9 View Post
    http://www.fabathome.org/wiki/index....For_Solidworks
    Apr 2004
    You might also want to look into the RepRap -- if it takes off the way they designers envision it should end up very cheap. At a talk this last october, they were envisioning the cost of building one to be around $400.
    C makes it easy to shoot yourself in the foot.
    C++ makes it harder, but when you do it blows your whole leg off.
  • Page 1 of 2 12 LastLast
