| Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here. |
Has anybody used a 4-th axis head mount like this and did it work very well? I've been looking at all of the 3axis units but will need to undercut more and don't want a lathe style rotation. This is what i've been thinking about. The small hole at the top of the large gear is for a zero locator (ir transmitter/reciever pair) actual hole would be very small. Use an idler gear to connect the stepper to the motor. At zero a simple solenoid could lock the gear in place using the top gear spacing. The back plate keeps it from rotating all the way around (switches for stop points added of course). I could get a decent angle without having to use a complex wiring setup for the z axis and router power. It wouldn't rotate around itself and twist the cables to pieces. Of course the angle would depend on the router mount and table size. I could make a stiff enough gang beam making a sandwich of mdf, foam, and fiberglass with a pipe and bushing insert. I'm going back and forth between thoughts of using a smaller spindle and smoothing out a piece of copper plumbing pipe for the bushing or, trying my hand pouring a babbit bearing. I was shown Mach3 and its configurability would work for this head. The large mounting plate and spindle would be an aluminum disc with an adaptor to either 2 or 3 inch steel plumbing pipe. The z-axis would use a spindle extension with a floating brace to get an extra couple inches of travel to make the angle usable. Right now its just an idea, if anybody has a better one let me know please. |
I want to see more and where this device connects to the router. My thought was to have one end of my table with this hanging from it free whelling. The stepper that has the other end holding the product and rotating would be clamped to the bed of the table at whatever lenght I wanted so on my 5' table i could do a 8in piece or a 48" piece lathe like. That way I get the full Y and Z ability... I will make a drawing real quick of my idea and you have to look at my table real quick so it makes sense. Steele and aluminum first project Wanted to add the concept here it is...
__________________ Building Stage:[xxxxxxxxxxxxxxxxxxxx] 105% Finishing Stage:[xxxxxxxxxxxxxxxxxxx-] 95% Last edited by Coogrrr; 01-10-2007 at 09:09 PM. |
I was thinking about this basic style of y-axis. I'm thinking drill rod for the long pieces and mounting them with jgro's end blocks. It would be easy enough to attach (weld) an adjustable center mount for flex. I would use plate for the sides and make an aluminum box for the cross pieces. A boxed square opening could be easily put in the cross pieces then the tubes filled with expanding foam. Gusset plates would go on the outside to strengthen the gantry. I don't know and would appreciate comments on whether it would be better to use a moving table or moving gantry for strength. I know the moving table takes up more room. A 4 foot span would use just over 8' with the moving table, and just over 6' with a stationary. |
I was thinking about using this style of mount for the z-axis to keep the distance from the router to the support bearing shallow. Its not shown but the hole would be completely through the slide, using nuts at the upper and lower end. I mentioned earlier possiby using a spindle extension but that is beyond my means. Careful router choice would work along with a little bit of parts blocking to raise off the table. Has anybody used something like this? Is it worth pursuing? Ideas? Comments? Last edited by rovingmind; 01-12-2007 at 11:06 AM. Reason: additionaly I know the threads aren't shown, these are quickly modeled, that kind of detail would come with a dimensionaly accurate model |
| Ok i added threads to the drive rods although its still not dimensionaly accurate. Any ideas yet? Has anybody tried this on a homebuilt before? After looking at nema 34 steppers I'm thinking they would be the smallest stepper used practially, for this size of machine. It also became readily apparent that the z-axis would have to run this way to get any depth. a basic "Doh" on my part initially. Bracket is simple porter-cable clamp design for now. Last edited by rovingmind; 01-13-2007 at 03:21 PM. |
| Interesting idea, but before you put too much effort into it you need to think carefully about how you are going to use it. The code generation for this would be extreemly complex. I don't think the out of the box code generation solutions would work for this. I'm not saying it can't be done. It would just be a shame if you put all the effort into building it and never be able to use it. Paul |
Can you point me towards any other ideas? (besides the a-axis lathe style) |
| I'm not sure, but I think with an axis like this, the centre of rotation is set to the tip of the bit which makes it much simpler to control. I dont think you could do this with a gantry machine as the gantry would collide with the work piece. I think with gantrys the common solution is the one Coogrr sketched. The math for your idea would be quite complex and you would proberbly have to write the software yourself. Please dont think I'm trying to pour cold water on your idea. I just want to make sure you know what you are getting into. Paul |
#10
Bobcad mentions the ability to use 4th axis indexing for cam toolpath generation. Of course without the machine to test with i cant really test them out fully with the idea. A gantry width of 4 feet on a workpiece 18" wide should get enough space at the side to keep the top of the mast clear on tool retraction if something went wrong. Thats also why the head sits forward of the mast sides. It should be able to slide all the way to the side stops even with the head tilted. At the moment its a research project for me. I'm planning on building joes kit after i get a small metal lathe first. |
#11
| Like this Although upon rotating it through its motions, the bottom corners of the z-axis slide would have to be rounded off and usable table space becomes rather small for the y axis. the straight up and down z-axis will not work to get the motion of freedom needed and tilting the table wouldn't work. Aaargh!!! Last edited by rovingmind; 01-13-2007 at 04:31 PM. |
#12
| For me this design is dead. If anybody does build something like this I would like to see it. The size of the table to do something like this makes it a no-go for me. The Table clearance is a non-issue and a moving table, fixed gantry gives the support for the higher gantry head but 4x8 panel cutter size is needed to make the extra angle useful for anything. |
