Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
  #121   Ban this user!
Old 01-01-2008, 08:33 PM
twistedfuse is on a distinguished road
Shannon,
Great job. Stumbled across this thread the other day as i have been looking for something like this for my own chains along with a mini cyclone(Damn MDF dust clogs the filters) for my next couple of projects for my mahcine.
This is another one of these great posts that everyone will refere to and it will help every hobbyist make a professional looking machine cheaply and easily. Again its another step towards a completely homemade machine. Great work.
Looking forward to cutting my own chains for my machine soon. You've just saved me alot of money.
Thanks again.
Daniel
P.S Now if only someone can't make their own cheap CO2 laser. lol
Old 01-01-2008, 11:12 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
I'm trying to see what keeps them locked together?
Joe
  #123   Ban this user!
Old 01-01-2008, 11:18 PM
Big S is on a distinguished road
Hi Joe,
The outsides face each other so one link is comprised of two 'pin' side pieces facing inwards, the next link is comprised of two 'hole' side pieces facing outwards. When the top and bottom plates are attached they then hold the whole lot together.
I can put up some pics to make it clearer if you like?
Shannon.
  #124   Ban this user!
Old 01-01-2008, 11:25 PM
Here's some pics to make it clearer.
Enjoy....
ID:	49696   Click image for larger version
ID:	49697   Click image for larger version
Old 01-01-2008, 11:34 PM
joecnc2006's Avatar
www.joescnc.com
i see how you have it, i was just curious what keeps the sides from sliding outwards other than a tight fit of the top and bottom pieces, but i tight fit should work fine.
Joe
  #126   Ban this user!
Old 01-01-2008, 11:39 PM
Friction fit.
I am thinking with the acrylic they can be glued (carefully) with some sort of solvent, the chain in my previous photos is a really tight fit and shouldn't come apart under normal use. Saying that, I may still end up gluing it all together.
Shannon.
  #127   Ban this user!
Old 01-03-2008, 09:20 PM
flyboy1015 is on a distinguished road
Thanks for sharing. Just found the thread after seeing the pics in the gallery a few days ago. Great job. I've been thinking about this for a while. Kudos on your work.
My Solsylva machine (my first cnc)
http://www.cnczone.com/forums/showthread.php?t=44336
  #128   Ban this user!
Old 01-03-2008, 09:28 PM
No problemo I now need to finish a machine so I can use some of it
Everyone don't forget to put some pics up when/if you have made some.
Shannon.
  #129   Ban this user!
Old 02-04-2008, 08:29 AM
Khalid's Avatar
Khalid is on a distinguished road
good job
if some body still copying then pls post some more pics
  #130   Ban this user!
Old 03-16-2008, 11:37 AM
drafterman is on a distinguished road
I have been using some bonded hydraulic hose for a cable carrier. It is basically four 3/16" dia. hoses bonded together side by side. The hose is very flexible so it has a good bend radius, but it doesn't "walk" around as it rolls. I can pass my motor wires through one wire, limit switch wires through another, and 110V through yet another. I have about 10 months of use without any failure. You can find this in various diameters and numbers of "circuits". I crimped regular hydraulic fittings on the ends of the hoses and then used bulkhead fittings to attach them to my machine.
drafterman
  #131   Ban this user!
Old 07-24-2008, 04:56 PM
mindstorm88 is on a distinguished road
See my carrier from this design in my thread :http://www.cnczone.com/forums/showthread.php?t=61076
  #132   Ban this user!
Old 07-29-2008, 02:47 AM
DougO is on a distinguished road
Big S, thanks for sharing your ideas. This looks like the way to go.
Does anyone have the file in Vcarve format? I loaded the posted dxf file into Vcarve but the parts were huge and I don't know how or what dimensions to make them. After I loaded the file into Vcarve, the individual parts might fit on a 4x8 sheet of plywood.
thanks,
Doug
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
