Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
  #25   Ban this user!
Old 05-10-2008, 05:43 AM
marvfrankel is on a distinguished road
Limit/Home switch wiring
Jerry,
I realize that it's been some time since you originally posted the wiring diagram, but it really helped me understand things a lot better. Although your diagram shows both limit and home switches, I understand that Mach3 will allow you to use one axis switch for both limit and home functions. I'm presently wiring my Bridgeport Series I, which has Normally Open switches. The X and Y axes each have one switch, and the Z axis has 3switches. I'm going to connect the uppermost switch on Z to the breakout board. Please let me know if I'm on the right track.
Marv Frankel
Los Angeles
Old 05-10-2008, 06:12 AM
Gold Member
CJL5585 is on a distinguished road
Marv,
You are on the right track. The drawing was made to indicate how the system should be wired Failsafe in an industrial environment.
You are correct, in that Mach can know the physical location of a switch and can through the software create and determine software home and limit switches. Also the physical switch can be set as normally open or closed in software.
Goodluck on your project. I have not been active on this site for a couple of years, as I have been involved in other projects.
Glad you took the time to let me know that the drawing was not in vain.
Thanks,
Jerry
  #27   Ban this user!
Old 09-17-2008, 02:28 AM
student1616 is on a distinguished road
i have a doubt here.
i agree using the limits as home switches(as mach is capable of doing that)
but what abt wiring the limits in series.
say iam jogging towards X+ and touched that side limit.now iam supposed to jog towards X-(using limit override function).here how the mach know which side iam jogging.as the limits are in over ride condition and we wired them in series mach dosen't know which side is to jog and which side to stop.
i tried this on my machine.the axis touched the X+ limit,so i clicked limit override and again jogged toward X+ and it crossed the limit.
so how safe it is.(am i doing something wrong here)
i was planning for another parallelport,so that i can assign separate input for each limit switch.imean for X+ and X-
  #28   Ban this user!
Old 11-14-2009, 09:22 PM
Snap is on a distinguished road
Im just happy to be here
I don't have an opinion about the thread but I love electronics and talking about them. Keep going.
  #29   Ban this user!
Old 02-23-2010, 07:28 PM
mwjohnson is on a distinguished road
Jerry,
Newbie to this CNC stuff. I wanted to hook up to my laptop computer with the USB port, so I bought the SmoothStepper controller and the SmoothStepper break out board. My problem is I don't know how to hook up the SmoothStepper break out board to Keling 4030 drivers and if I need an external 5vdc power supply or not.
Old 02-23-2010, 09:38 PM
Gold Member
Originally Posted by mwjohnson View Post
Jerry,
1. Hooking up the Break out board to the Keling 4030 Drivers. Here is a factory link with pdf file for downloading.
www.kelinginc.net/KL-4030.pdf
2. External power supply 5 Volts DC
You should not need an external 5 Volt supply.
Jerry
  #31   Ban this user!
Old 02-24-2010, 04:02 AM
Jerry,
Thank you very much for the info.
Another thing I am confused about is the manual that comes with the Smooth Stepper break out board:
http://cnc4pc.com/Tech_Docs/C25R1_1_USER_MANUAL.pdf
On the board it says: Port 2 Pins 2-9 for Input
In the manual further down on page 3 #4 it says: Inputs 2-9 (Port 1 simplified.......... right below Fig. 1 says .....for the port 1 outputs 2-9.
Down further on the page in 4.2, the same thing happens for Port 2.
I suppose I should just contact Smooth Stepper or CNC4PC, but you seem to respond very quickly and in terms that I can understand, so any help that you can give me would be greatly appreciated. I'm being very cautious before powering up, so I don't damage anything. The boards are kind of pricey.
Old 02-24-2010, 10:41 AM
Gold Member
Jerry,
My Response:
On page 2, Section 3, under Specifications, the number of digital inputs are listed as follows:
5@ port 1 13@ port 1
I think this is most likely an error in printing the manual. It is my personal belief that it should read as follows:
5 @ Port 1 13 @ Port 2
Also, under the same Specification heading is listed the digital outputs. It shows 12 digital outputs at Port 1 and 4 digital outputs at Port 2. This statement appears to be correct. If you will compare the total inputs and outputs of each port (as I believe they should be) you will find the following:
Port 1:
Inputs 5 Outputs 12 Total = 17
Port 2:
Inputs 13 Outputs 4 Total = 17
I also believe that some of the diagrams in Section 4 are mis-labeled such as Outputs being called Inputs and so forth.
Something that is VERY CONFUSING to many people is that they want to use the inputs to wire up the step and direction signals to the drivers. This is not correct.
FOR CORRECT WIRING OF THE STEP AND DIRECTION SIGNALS from the breakout board to the motor driver modules:
Use Port 1
IN MACH 3 SET OUTPUTS ON THE FOLLOWING PINS (2 thru 9) TO ACTIVE LOW WHICH TRANSLATES TO ACTIVE UPON TRANSITION FROM 5 VOLTS TO 0 VOLTS DC. If the system does not operate correctly, set the ABOVE output pins to ACTIVE HIGH.
Pin #1 not used
Pin #2 Step signal to Driver Motor #1
Pin #3 Direction signal for Driver Motor #1
Pin #4 Step signal to Driver Motor #2
Pin #5 Direction signal for Driver Motor #2
Pin #6 Step signal to Driver Motor #3
Pin #7 Direction signal for Driver Motor #3
Pin #8 Step signal to Driver Motor #4 If used
Pin #9 Direction signal for Driver Motor #4 If used
Hope this helps in your endeavor. Good luck.
Jerry
Old 02-24-2010, 11:28 AM
Gold Member
Pin # was used to define Terminal#
I used the old terminology of pin (as denoted on a parallel printer port breakout board) without my brain reminding me that you were working with terminal numbers.
So, the pin numbers in the above post are the actual terminals on the different ports.
Did not want to create any confusion on this point.
Jerry
  #34   Ban this user!
Old 02-24-2010, 03:39 PM
Thank you much Jerry!
I beleive I understand now, and I'm ready to move forward.
The info. you gave me was exactly what I was looking for.
Mike
