Page 1 of 4 1234 LastLast
Results 1 to 12 of 40
Thread: Has anyone tried fiberglass?
    Mar 2004
    Fiberglass can be extremely strong, if done properly. Perhaps some stressed fiberglass skin panels with foam or wood core would be a good material choice for some components of a DIY CNC router project. Not the bed but perhaps uprights and/or bridge.
    Has anyone tried it? Any thoughts?
    Moderator
    Sep 2005
    I haven't built a fiberglass CNC anything.. but I have built a fiberglass airplane . My recommendation would be to skip fiberglass and go w/ Carbon. For the same thickness you'd be way stiffer than glass. You could also use Kevlar 49 [or is it 29?] in it as well, Kevlar is known for its vibration dampening properties, which would be a great asset on a mill or router. I'd build the basic structure out of carbon and foam, then just wrap it in kevlar [little if any cutting of the kevlar if possible as its a realy pain to cut] and then cap that all w/ either carbon or glass.
    There's no doubt that it could be made strong enough. Alot of cars now have the structural support in their bumpers, made from glass. As well as the impact beams in car doors are built w/ glass.
    It wouldn't be cheap however.. But if you were going to do PCB milling or light engraving and wanted a super fast machine.. it'd be the way to go for sure. Imagine 0-1000ipm in 1/4" inch.. that'd be some acceleration eh?
    My 2 cents..
    Jerry [someday I just might have to try this ]
    JerryFlyGuy
    The more I know... the more I realize I don't
    Aug 2006
    I'm also into planes, and about to make a machine... and it'll have glass all over it.
    Carbon and Kevlar are stronger, but multiples of the price. We're not building a plane, so weight isn't quite the premium... so... with a wodden substructure, and a glass shell... methinks it'll be generally improved for the effort that goes into it. I'm also going to laminate thinner plywood pieces either side of glass and then glass the exterior... it should make the whole thing very stable to things like moisture or whatever.
    ...anyways, fiberglass? yes, have some!
    Moderator
    Sep 2005
    Carbon and kevlar will be more money per foot/yard. But I think the $/psi strength actually isn't that far off. In other words, to get the fiberglass structure to be as stiff as the carbon or kevlar one, the price won't be terribly different. If you've already got the Fiberglass I'd say go for it
    As far as your structure, if your using wood as a base, don't bother putting glass between pc's of wood. You'll not see any increased performance. Just bond the pc's of wood together and put the glass on the outside. If your taking about a cavity structure [ that is hollow] then glass on the inside is probably a decent idea, that is.. if mositure can get in there to attack the wood. If its an entirely sealed box, I'm not sure you'll see any advantage.
    Jerry [2 more cents ]
    JerryFlyGuy
    Mar 2003
    Shelby Twp, MI....USA
    This guy intends to build his machine from carbon fiber after he gets the mdf mockup running. Slow progress, though.
    Not sure I'm ready for this - I've started building!
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    i've fibreglass coated a previous mdf gantry i had built ,took a fair bit to break it up to through it into the garbage bin , it was tuff and waterproof ,which was the reason i did it , lots of moisture in BC
    Jun 2003
    Keep in mind that resin shrinks over time, as much as 5% which may be an issue for accuracy. Glass over an mdf frame would be better than pure glass as the mdf will help control shrinkage but use some thaught in the design so that whatever shrinkage occours it is exposed as equally as possible over the whole machine so that it dose not warp or bow.
    Cheers
    Splint
    Mar 2005
    U.S.
    if you use epoxy resin you won't have the shrinkage issue. however, the cost will be greater.
    Aug 2006
    Some interesting opinions, and it's good to hear dertsap's clarity of experience... it also mirrors everything I've ever done with fiberglass myself.
    The gantry box has the most to gain from it. I'll be making each panel out of laminates with two layers of different oriented glass in the middle. This will make each panel much stronger alone than just an equally thick piece of wood that would be the result.
    However the most strength will be gained after assembling the box, if the outside is given a shell of a couple of layers of glass: it will become very rigid. Carbon and Kevlar would be overkill. In fact, Kevlar wouldn't really provide any more strength at all, as it has different properties, and is best at resisting shearing forces. Carbon is more rigid, but for this purpose, a waste of money... carbon is much dearer lately.
    Regards shrinkage... this glass CNC beast will be a fiberglass shell around a heavy enclosed wooden structure... if it shrinks it'll actually make the thing even stronger! (because the glass is strinking around the structure, making it all tighter)
    ...eitherway, I'm up for a bunch of glassing when the time comes.
    Mar 2004
    Kevlar is a lousy material for a router. It is strong in ways it doesn't need to be for a mill project and not strong in ways a mill requires.
    Carbon fiber is more rigid than glass but expensive. I think glass could do a very good job if done properly. Vacuum bagging would be a given, on account of the high frequency vibration it would be subjected to.
    One of the things that made me think of glass is that I cut a lot of aluminum and sometimes I use carbide tipped wood tools like the table saw. A carbide tipped blade or router bit will cut aluminum like butter as long as you keep the blade lubricated with WD-40.
    I intend to build the Joe 2006 r2 CNC router but I worry about the compatability of MDF and WD-40 or other lubricant.
    Moderator
    Sep 2005
    Guy's can you explain a bit more why Kevlar is such a bad choice for a mill? I'm not following. Anything that I've read would lead me to think it would be a great choice for a fairly stiff structure which needs as much vibration dampening as possible.
    Curious..
    Jerry
    JerryFlyGuy
    Mar 2004
    The disadvantages of kevlar are poor compressive qualities, it is stretchy (particularly grade 29), the fibers absorb moisture, very difficult to work with (difficult to cut and drill through, even when cured).
    Being so nasty to work with is what makes it great at what it does best. I've used it on boat keels and areas where abrasion resistance is desireable.
    I think epoxy/glass is the answer. It's cheap and extremely strong.
  • Page 1 of 4 1234 LastLast
