Results 1 to 3 of 3
Thread: need info on additional hardware
    May 2006
    I recently acquried this set-up
    It is a 3 axis machine:x,y,z with 2-phase motors.(one of the slides is missing)
    I want to mount a router(horizotal) on the top and use this for woodworking(make mortise and tenons)
    I would like to use the existing motors(Vexta) and setup.
    What drivers do I need? Where do I get them? Where can I get info on this?
    thanks ..... joe
    Registered ahren's Avatar
    Feb 2004
    Joe, since these are 2 phase motors, you can use a G540 or other Gecko stepper motor driver to move them, and connect this with Mach 3. I'd highly recommend this over trying to find Vexta / Oriental Motor drivers to go with your drives, as these will cost more and offer less performance.
    That being said, while I can't find a lot of information on these motors, what I did see leads me to believe these are fairly high inductance motors, as they have a low current rating and high voltage rating. Since they only run about 0.4A/phase, them may require a high voltage power supply to get much out of them. You might consider swapping the whole electronics setup at some point, but you could start with a G540 and a 7.3A 48V supply.
    Best regards,
    Ahren
    CNCRouterParts
    May 2006
    Smile Definitely work in progress
    OK; that is great,now i have a place to start
    I'll keep you posted on my progress.
    This is definitely trial and error(s)
    thanks.......joe
  1. Need Help!- HAAS VF1 additional sensor
    By CoachWorkman in forum Haas Mills
    Last Post: 05-09-2012, 02:45 PM
  2. Additional Pseudo Axis
    By mackeym in forum General Metal Working Machines
    Last Post: 08-14-2008, 06:21 PM
  3. Mach & Additional IOs
    By aus-newb in forum Mach Lathe
    Last Post: 12-18-2006, 11:07 AM
  4. Need Info on Hardware suppliers
    By speedster in forum General Waterjet
    Last Post: 08-14-2006, 08:47 PM
  5. Additional forum
    By HuFlungDung in forum General Metal Working Machines
    Last Post: 03-03-2003, 08:52 PM
