Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
Old 12-11-2005, 07:30 PM
Smackre is on a distinguished road
4 Axis Cnc Bowling Ball Driller
I was designing a Cnc Bowling ball Driller. I have been sketching it up in autocad for afew weeks now. Id perfer 5 axis but i cant find any controllers for that. So im going with 4 axis. X/Y/A/B. Then i will control the drill bit debth my self.
I am not sure on which servo's / controller / software i should get yet.
Here is my design so far. Tell me what you guys think. BTW the peice the ball is sitting on in the picture turns for the B axis and the whole canapy pivits for the A axis. Then its sitting on a X,Y table.
All the holes in the canapy are for 1/4" all thread.
I will put it all in a large drill press or mill. I plan on using a vacuum device to hold the ball down. However i am unsure if this will have enough suction to hold the ball when the canapy is tilted up on large angles like 60 degrees.
Thanks,
Old 12-11-2005, 08:02 PM
ViperTX is on a distinguished road
When holes are drilled in bowling balls are they always perpendicular to the surface....it seems to me that they are not....
Old 12-11-2005, 08:06 PM
No they vary. I perfer to have some forward pitch on my finger holes and alittle side pitch on my thumb hole.
