Results 1 to 4 of 4
Thread: rj11 limit switch wiring through cable chain
    Feb 2007
    Hi I am using cncrouterparts breakout board, which uses rj11 jacks.
    I am considering using round cat 3 utp 24awg phone line for my limit switches.
    It is solid wire, not stranded and I know it's not the best choice for flexing applications, but Im wondering if anyone has used it, and what sort of life expectancy can I expect. Is that flat telephone cable good for repeated flexing?
    Thanks.
    Dec 2003
    In a machine application you should never use solid conductor, even in non-flexing applications, vibration can cause fractures.
    Feb 2007
    on my lunch break picked up from radioshack 278-0367. It's 26awg stranded. 7 tiny strands in there. ill see how it holds up.
    thanks
    Registered planekrazie's Avatar
    Apr 2006
    Hello Alan
    Its been a while since posts were made to your thread. If you run your limit switch wire through your cable carrier then you may run into noise causing a fake limit switch alarm.
    just a sug.
    Steve
  1. Newbie- Wiring limit switches using schielded cable
    By Action-KAT in forum DIY CNC Router Table Machines
    Last Post: 01-14-2011, 08:46 PM
  2. Home/Limit switch Cable HELP!!!
    By planekrazie in forum DIY CNC Router Table Machines
    Last Post: 04-27-2009, 08:40 PM
  3. limit switch wiring with shielded cable
    By endgrainguy in forum General Electronics Discussion
    Last Post: 05-05-2008, 01:22 AM
  4. Limit Switch Wiring
    By The Speaker Guy in forum General Electronics Discussion
    Last Post: 01-07-2007, 05:11 AM
  5. Limit & Home Switch Wiring?
    By Willyb in forum Gecko Drives
    Last Post: 10-17-2005, 05:02 PM
