Page 2 of 2 FirstFirst 12
Results 13 to 17 of 17
Thread: 4x8 new router build Electronics
  1. #13
    Registered hacker7's Avatar
    Nov 2009
    united states
    Ok this is what I'm talking about !!! Great Feedback!!!!!See I've already built one machine which runs with a Gecko g540 and CNC ROUTER PARTS 380oz/in steppers and belt reduction units. It's 4x4, but just need a bigger machine now, and I really like what PMDX has done with their components so they integrate with Gecko drivers perfectly. Also the "fanless" idea with the big heatsink is also good idea. IF............. I use what I had stated in the beginning, is this a good setup? Other than the power supply being on the big side. And which one should I use? Will this let me cut birch plywood at say 100IPM in one pass using a PC 7518 router? The hardwood flooring that I've been doing is mainly alot of inlays no deeper than 3/8. But when I cut the whole design out I would like to cut it in one pass if possible. Thanks for the valuable info guy's.
    Richard
  2. #14
    Mar 2003
    Shelby Twp, MI....USA
    As I said before, your spindle and tool choice will be the limiting factor in how fast you can cut. 100ipm is actually very slow. You're current machine should be capable of 3 times that, if the spindle is up to it.
  3. #15
    Nov 2009
    united states
    Thanks ger21 the machine I have use's a Porter Cable 690 . It will not cut 3/4 birch ply in one pass at 60 ipm. It's just not strong enough. The new machine will use a Porter Cable 7518 3hp.I only use Onsrud bits 1/4, 1/2. Thanks
  4. #16
    Mar 2003
    Does the spindle stall?
    A 690 should be able to cut over 100ipm easily. Is this baltic birch plywood, or regular plywood? What specific bit's are you using?
    At 60ipm, a 690 spinning at 27,000 rpm would dull the bits very quickly from excessive heat. Changing tool type can make a big difference. You can also try making 3 passes at 300-400ipm, which would still be faster than 1 pass at 60ipm.
  • #17
    Nov 2009
    united states
    Kinda ,yes it just slows down as if the feed rate is too fast. The bit is a Onsrud 60-005HH - Spiral Chipbreaker, Helix High, Solid Carbide, 3 Cutting Edges. I've replaced the bearings twice in 3yrs. But I do cut alot of 3/4 standard birch plywood. And just in the past yr have been cutting floor inlays.
  • Page 2 of 2 FirstFirst 12
    1. New Machine Build- NEW MACHINE BUILD: 5 X 10 Plasma with CandCNC Electronics
      By fabguy in forum Plasma, EDM and other similar machine Project Log
      Last Post: 02-29-2012, 10:56 PM
    2. Build thread - UCNC: First Step - Electronics
      By kuolas in forum Open Source Controller Boards
      Last Post: 10-16-2010, 11:05 AM
    3. Designing and Build Outdoor Enclosures for Electronics
      By ViperTX in forum Suggestions for the CNCzone.com site.
      Last Post: 08-29-2009, 12:06 AM
    4. Electronics Enclosure Build
      By BobWarfield in forum Industrial Hobbies (Support forum)
      Last Post: 04-08-2009, 10:37 AM
    5. Newbie- Help with electronics - 1st build
      By wprysock in forum DIY CNC Router Table Machines
      Last Post: 10-28-2008, 11:44 PM
