Results 1 to 2 of 2
Thread: Nema motor Power supply
    Registered aquaveg's Avatar
    Dec 2011
    The CNC unit i am building has Nema 34 stepper motors 879oz, The power supply included was a 24 volt unit rated at 15 amps.My question is there any advantage upgrading to a 36 volt power supply will this increase speed and torque of the stepper motors. Just curious thanks.
    Oct 2004
    Quote Originally Posted by aquaveg View Post
    Increasing voltage has to be compatible with the drive unit you're using. If the drive unit is up for it then speed and torque would go up as well as acceleration and on the negative side the heating of the stepper. You have to ask yourself if you really need the added voltage to accomplish your task.
    Chris
  1. G540,620 oz nema 23, what power supply and winding?
    By umustsurf in forum Gecko Drives
    Last Post: 09-16-2011, 01:50 PM
  2. Newbie- Stepper motor power supply
    By naveen.a019 in forum Stepper Motors and Drives
    Last Post: 06-10-2011, 01:16 PM
  3. Need Help!- Power Supply and motor requirements
    By tizdall in forum DIY CNC Router Table Machines
    Last Post: 01-01-2011, 01:40 PM
  4. Power supply for stepper motor
    By gaga2410 in forum Stepper Motors and Drives
    Last Post: 11-08-2007, 06:42 PM
  5. Power supply and Nema 17
    By woodturn in forum Stepper Motors and Drives
    Last Post: 02-13-2007, 11:11 AM
