Page 2 of 8 FirstFirst 12345 ... LastLast
Results 13 to 24 of 92
Thread: Also building a CRP4848
  1. #13
    Feb 2011
    Just wanted to say Thank You to both Jibber and Wolfspaw for the nice comments. My best to both of you. I hope my postings are helping others out.
  2. #14
    Aug 2004
    Best post yet on building alum erector set type machine .
    sincerely ,
    eigstein
  3. #15
    Aug 2011
    Switzerland
    Thank you
    Thank you for taking the time to do the detailed videos, I am three steps behind you in the assembly of my CRP4848 but I now watch your video of each step before I proceed as there are some great tips.
    I am impressed with how well engineered and complete the kits are from CNC Router Parts and accuracy that is emerging during the build.
    Cheers
    John
  4. #16
    vrf
    vrf is offline
    Sep 2009
    Great tips in your videos. It'll be a huge help for helping me with my own build.
  • #17
    Jan 2005
    I hope you continue with this thread right up through your first cuts. As you can see, you have a bunch of interested followers.
    Wolfspaw
  • #18
    Jan 2011
    I recently purchased one of these kits and while I haven't gotten all the parts yet, I greatly appreciate these videos, because I'm still a bit intimidated at the prospect of assembling one of these. I'm sure these videos will help. I'd also love to see how you fine tune the machine after it's all assembled and running!
  • #19
    Jun 2009
    Yes yes, please keep the vids coming!! We are all loving this!!
  • #20
    Feb 2011
    I just want to say Thank You, to everyone that left comments, it is appreciated. I am glad that so far my post's are helping those that are building, going to build, or are thinking about building one of these machines. I plan to keep going with posts beyond the first cuts to show what this machine can do. My best to everyone.
  • #21
    Feb 2011
    Z-Axis final assembly and X-Axis R&P component review.
    For the Z-Axis, I locked the Heli-Coil onto the lead screw and remove the bearing/screw assembly. I then took the Lead Screw Nut and ran it up the lead screw to snug up the thrust bearings and tightened the Locking Collar around the lead screw. I the reassembled everything and removed the motor. Next slide the Z-Axis between the upper bearings on the Z/Y Plate and gently screw into the Lead Screw Nut. Turn the lead screw until you get it through the bottom bearings. Then tension the carriage bolts and clamp the carriages together. Finally tighten the bolts to the carriage. Last mount the motor and tighten the Heli-Coil to the motor shaft. The pictures show the final Z-Axis and the R&P components.
    Attached Thumbnails Attached Thumbnails Also building a CRP4848-z-axis-7.jpg   Also building a CRP4848-z-axis-8.jpg   Also building a CRP4848-z-axis-9.jpg   Also building a CRP4848-x-axis-2.jpg
  • #22
    Dec 2011
    thanks!
    I am also building the 4x4, and while i didnt find this until I finished today, it has some great tips to get around some of the issues I hit as well. I also suspect my somewhat more lax attention to intense squareness will hit me later. I am getting started on the electronics in a couple days and look forward to seeing how you pull it all together.
    thanks for sharing in such detail!
  • #23
    Feb 2006
    U.S
    Motors and drivers
    Where did you get your motors and drivers from? what supplier?
  • #24
    Feb 2011
    X-Axis rack assembly and Spindle Mount
    The rack clamps start flush with the front of the machine, the back clamp ends at 54" from the front and the other 2 are 14" from each other between all of them. For the Spindle Mount I used 1/8" x 1/2" steel plate and cut 2 pieces at 3" in length. Drill 2 holes in each 1-1/2" apart and tapped 5/16-18 treads to make nut plate. The bolts are Socket Head Cap Screws 5/16-18 by .500 long for the Mount.
    Attached Thumbnails Attached Thumbnails Also building a CRP4848-x-axis-5.jpg   Also building a CRP4848-x-axis-6.jpg   Also building a CRP4848-spindle-1.jpg
  • Page 2 of 8 FirstFirst 12345 ... LastLast
    1. Newbie- Building my own CNC
      By Ridwan in forum Xylotex
      Last Post: 03-09-2012, 05:46 AM
    2. New Machine Build- My first CNC building
      By drRobutik in forum CNC Wood Router Project Log
      Last Post: 06-29-2010, 12:21 PM
    3. Building my first CNC
      By teslaprotege in forum Mechanical Calculations/Engineering Design
      Last Post: 04-28-2010, 08:37 PM
    4. help with BUILDING a cnc
      By MBG in forum Mentors & Apprentice Locator
      Last Post: 02-19-2008, 05:11 PM
    5. pod building help
      By arch1 in forum WoodWorking
      Last Post: 10-22-2007, 11:44 AM
