Results 1 to 10 of 10
Thread: Building a CNC machine
    Nov 2011
    cyprus
    Post Building a CNC machine
    Hi all,
    I actually need help building my CNC machine.
    I have bought a TB6560 driver but i do not know the proper configuration.
    I tried lot of things but it does not work. Actually not even the seller seem to know how to configure it .
    Does anyone fount the proper configuration to help me?
    Or do you suggest another diver?
    Thanks very much,
    any help would much appreciated.
    Registered bobsch's Avatar
    Oct 2008
    Try this thread http://www.cnczone.com/forums/genera...y_chinese.html for info on you drive. Good luck. You might want to check into a Gecko G540.
    Bob
    "Bad decisions make good stories."
    Nov 2011
    cyprus
    CNC Machine
    Thanks a lot!
    I will try it and hope it works.
    I think i will go into Geko but I would like to make that one works first, if not I will proceed with something else.
    Thanks again
    Nov 2011
    cyprus
    Building CNC
    Dear bobsch,
    I took the courage to ask you few things because I don't have any idea about cnc's, and I would like to learn and proceed.
    As I told you I bought the TB6560 because it was cheap and I would like to see the environment about cnc's before i buy something more expensive, but unfortunately I couldn't get it work. You suggested Gecko 540. I searched for it but because I am new I might need some help.
    What i actually would need with Gecko 540? Type of stepper motors, power supply? Is this actually a complete driver board or I need more components to get it work?
    Also, is it compatible with all OS, Mach3. What software to you suggest, if any?
    I am sorry for this long paragraph.
    Your help would be very important for me
    Thanks in advance
    Oct 2008
    Quote Originally Posted by Chiapaprikos View Post
    Here's an example of a setup using a G540 and 3 (or 4) NEMA23 steppers Page Title
    and here a sample wiring diagram to hook it all up http://www.kelinginc.net/G540WD.pdf The parallel port connector would connect to your computer and will work with Mach 3 or EMC.
    All that said, however, a lot depends on what size machine you want to build including the size, the type of mechanical drive (Acme, R&P, etc.) and what you want to cut.
    There's a ton of good advice on these forums and a lot of very helpful people who are great when it comes to answering questions.
    Good luck!
    Bob
    Nov 2011
    cyprus
    Thanks very much for all your help!!!!!!!!!!!!!!
    Apr 2011
    What cam software are you using?
    The TB6560 should have come with custom config files on the CD.
    I did the TB6560 route for a few months. It almost ruined my interest in CNC. It was nothing but frustration and heart breaks.
    Finally fried it crossing a motor wire.
    Went with the G540 and haven't looked back. The difference is night and day.
    If you need the TB6560 files let me know.
    Good luck,
    Jerry
    Boise
    Nov 2011
    cyprus
    Newbie Building a CNC machine
    Yes I know what you mean, I was very close to throw away everything but finally i got worked.
    TB6560 is cheaper and since is my first i bought it for test.
    I will work little time with it and then i will move to Gecko series.
    I have the files came with the cd but are not very clear,and i don't trust them.
    What programs do you suggest to use for my CNC. I have Mach3 and LazyCam which there were included.
    Thanks for everything!!!!
    Feb 2012
    Greece
    Hello Cyprus
    try to cnchobby.gr
    Nov 2011
    cyprus
    Can anyone help how to make an auto zero tool and enable probe for mach3?
    Any new ideas or recommandations, if there is another way is very wellcome.
    Thanks in advance
    1. New Machine Build- Building new CNC Machine
      By tinyron in forum General Waterjet
      Last Post: 04-27-2011, 09:30 AM
    2. Building a cnc machine
      By blklightning21 in forum DIY CNC Router Table Machines
      Last Post: 03-08-2011, 06:57 PM
    3. Building my first CNC machine
      By ATRepair in forum DIY CNC Router Table Machines
      Last Post: 10-30-2010, 07:44 PM
    4. New Machine Build- Anyone building this machine?
      By selbuss in forum Open Source CNC Machine Designs
      Last Post: 03-01-2009, 09:59 PM
    5. When you done building your CNC machine
      By Todd Price in forum DIY CNC Router Table Machines
      Last Post: 04-22-2004, 12:14 AM
