Just make the holes 1/32" bigger and be done with it, that's what I did. Once you torque the bolts, you won't have to worry about movement.
This is going to be my build thread of the FLA-100 Router. I plan to start posting pictures, maybe videos soon. I am going to be asking for tons of help here also, as this is my first cnc machine, ever.
First question of the day: I have drilled all of my cold rolled rails (carveone thankyou!, saved me $60 by using the jb weld idea..) And the holes are "pretty much there." The bolts fit nicely, however both x axis long rails and the y rail are a little off, even though I used a magnifying glass and a knife as a scribe, I still managed to be human I guess. The rails are not square to the 8020 frame. I think I found a solution and I want to pass it by everyone so I don't mess this up. I would re drill the holes 11/32 or 23/64 (3/8th seems too large) from the original 5/16 and now use the play to get the rails square to the extrusion. I think those 11 fully tightened bolts will prevent the rail from coming out of square while its running, but I could be wrong. What does everyone think?
I actually just ordered the steel rails to drill my self this week. Where did you get the dimensions of where the holes should be placed? Im assuming its about half and inch for overhang plus 3/4 inch to get the rest of the way to the center of the t-slot. So it would be something like this.
|----1.25"---|--0.75"----|
[ ========| |======= ] <-- That's an end on look at the 2" rail
Thanks for the heads up.
Steve
Check out my 8020 build
http://stevetotheo.blogspot.com/
The big rail is 2.25 - 1.5 - 2.25, with the 1.5 being the gap between the 2 screw holes.
The two thin rails have holes .75" from the side that you do not want the carriages to ride. Spacing is up to you but you can get the exact spacing from the e-drawings that are on the fla website.
Glad to see your progress! Im only a little ahead of you.
lol. I wasn't going to even work on my machine today but after seeing this I had to. I'm still lacking drive screws and other power train stuff but I was glad to get everything mocked up. I need to trim the z rail and 8020 support.
I'm pretty much finished! I setup the new dust extractor and now I just need to install the k2 mount and mill a dust shoe. Should be fun.
Also, I have a 1/4in endmill that I am thinking of using to surface the entire MDF cutting area... how deep should I surface, 1/8th in?
Honeywell hall sensors. They are DIY using the ideas from this thread: http://www.cnczone.com/forums/open_s...e_easy-37.html
I changed it so that the led is always on if the limit sw is plugged in. Using phone rj11 wiring and sockets. working swell so far.
Goop is your friend in setting these up. I like them.
Yes, Unless you have a cnc to cut the holes already, I dont think a human can get all holes aligned properly. I used 11/32 bits.
Sorry for lack of updates. Looks like all is working well and I have already made some first cuts! I have yet to surface the table but im just doing test cuts and learning for now anyway. New pics coming soon.
Hi everyone, machine has been running great, however I am getting tiny flakes of steel, almost gold flake in thickness on the rails which eventually makes the carriages noisy while moving and im sure it is affecting accuracy. How do I fix this? I will upload pics later.
Making chips, day by day
Oh yeah, 100% sure they are steel. I think its coming off the cold rolled rails. They easily are picked up by the magnet.
Pics:
I can take more pics if these are out of focus.
You should not be getting steel flakes!
Something might be sliding rather than rolling. Do you see the flakes on each axis or just one? If on one axis, is it mostly on one part of the axis? If so I'd look there to make certain that all the wheels are turning. If the flakes are everywhere and fairly uniform on each axis, I'd worry about a defect in the cold rolled steel. Or many sliding rather than rolling wheels!
It is on the X and Y axis. It only accumulates on one side of the cold steel. All of the bearings are properly contacting the steel and rolling. I cannot manually move any of the bearings by hand. The only idea I have is that I might have clamped down the carriage blocks too much when I tightened them up and now the bearings are hugging the steel rails so hard that they are being slowly 'eroded' from the weight and pressure. Any ideas?
