Just got my cnc router table up and running. Still need to do limit switches, but it works. IT WORKS!!!
Couple of questions does anyone have a preference between the flat vs pyramid ground engraving cutters? Does one cut cleaner then the other?
Also any suggestions on what to do with it now.I know funny question but seriously any cool ideas on what to make? And is there a problem with using a 1/2 inch shank flycutter to surface the spoil board? Wouldn't be balanced, but I am not sure if the router bearings will mind that much.
Thanks all
I would be scared to try that. At 20,000rpm the bit could be a deadly projectile if it came loose.
Alan
